Fusing Question. ***I searched, but still have questions... - Car Audio Classifieds!
Old 06-21-2010, 03:46 PM
0/11 ssssss286
Default Fusing Question. ***I searched, but still have questions...
I will be running...
Optima Red Top under the hood
Optima Yellow Top in the trunk
SAZ-1500D at 0.5 ohm (160A) sub stage
PA amp (25A) for front stage
1/0 Run from the front to back
My question is...what fuse do I use for...
From front to rear battery?
From rear battery to SAZ-1500D?
From rear battery to PA?
Also?
Do I just ground the rear battery in the trunk?
Old 06-21-2010, 03:53 PM
TurdFergueson2's Avatar
0/11 sssss3902
2 200s on the power run and you'll be good.
the 1500 has fuses as does the highs amp. you could get away with not fusing them.
Some people ground the back battery to the front. Mine are grounded in the rear. Not really sure if it makes a huge difference.
Anyone who hates civics is a rat and is trying to be destined for great things in life.
Old 06-21-2010, 04:08 PM
0/11 sssss6061
I wouldn't worry about running a second run for ground up front. Only if I was seriously competing.
Old 06-21-2010, 04:15 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Fuse within 18" of each battery when running your wire from the front battery to the back, fuses between the battery and amp are not required for your amps but they wouldn't hurt ether.
/ CAAA Member #2 /
Old 06-21-2010, 04:38 PM
0/11 ssssss286
thanks for the input. so a 200a on the power run about 12" from the front battery and on that SAME power run...put another 200A about 12" from the rear battery?
AND no need for fuses for the amps, as the amps are already fused?
did i get that correct?
Fusing multiple runs of 2/0 Cashdollar2009 General Car Audio Discussion & Questions 6 08-23-2010 01:13 PM
Fusing strapped AQ3500Ds area51 General Car Audio Discussion & Questions 11 03-06-2010 11:30 AM
fusing sk8infreak1 General Car Audio Discussion & Questions 5 02-27-2010 07:42 PM
Questions about my HU Ryan1126 General Car Audio Discussion & Questions 18 01-22-2010 07:51 AM
Fusing Q tater General Car Audio Discussion & Questions 11 01-27-2009 10:39 AM
