Blown Voice Coil? - Car Audio Classifieds!
Old 06-21-2010, 05:41 PM
brandonb1029's Avatar
FREE BOOSIE BADAZZ
0/11 ssssss755
Default Blown Voice Coil?
Below starts with what happened, and the question is the bolded paragraph...
Ok the subs are 2 DB Drive Platinum Series PT15D4.
One works properly. The other began making a a noise kind of like a crackling noise every now and then. Everytime I heard it I would check it out but then it would go away by the time I get out of car and go to the back... finally it became more constant, to where it would send my amp into protect mode, more quickly depending on volume. When both subs are wired together, both subs made this noise, when they were tested seperately only the one made this noise...
Basically, I took the sub out checked and saw nothing visably wrong, the only thing I found was that the connector on the box seemed to be bent, so I thought maybe the wire was coming lose. Replacing the wire led to it working outside my car for the hour or so of testing, however upon flipping the box to go back in my car and turning it on in there it did it again, and eventually blew the amp.
Since there is nothing visibly wrong with the sub, I am assuming it is something with the voice coil, I was wondering if there is a way to verify my assumption, with some tool or is there some way of testing this?
Edit: I am not too familiar with much car audio, except for basic installation, so I am not familiar with tools etc, I used wire stripper/crimper, scrissors, allen wrench, screwdrivers... nothing fancy.
Old 06-21-2010, 05:42 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Put a DMM on the coil and see what it reads
/ CAAA Member #2 /
Old 06-21-2010, 05:44 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
did you check the ohm load with a multimeter? could be the tinsel lead too
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Old 06-21-2010, 05:45 PM
FREE BOOSIE BADAZZ
0/11 ssssss755
Ok, would any work? Would I need an expensive one, or a cheap one from walmart should do the trick?
Old 06-21-2010, 05:47 PM
FREE BOOSIE BADAZZ
0/11 ssssss755
No, I have not, should all the coils read about the same thing? or how would I know if there is a problem with 1 or more of the coils?
Old 06-21-2010, 05:50 PM
x2o's Avatar
x2o x2o is offline
0/11 sssssss64
Any digital one will work for this purpose, be sure it is digital and not analog (Yes, they do still sell analogs ).
I bought a DMM at home depot I believe for about $15 that worked great and lasted about 2 years .
The System :
Electrical: Big 3, Powermaster D1200 and D3100.
Sub Stage : 18" Custom Sundown Nightshade D2
Sub Box : 4.6 Cubes tuned to 28hz
Sub Amp : Sundown SAZ-3000D
Headunit : Alpine 9887 ACTIVE
Front Stage : 2 10" Eminence Delta's and 2 Power Acoustik NX-5
Front Stage Amp : Kicker ZX350.4
Pro Audio (on a switch): (4) 8" Selenium 8W4P, (2) Selenium ST350
Pro Audio Amps (on a switch): Hifonics ZXi6010, Hifonics ZXi1010
Old 06-21-2010, 05:52 PM
x2o's Avatar
x2o x2o is offline
0/11 sssssss64
You would put the multimeter leads on the speaker's terminals, if it is a D4 sub each coil should read somewhere around 4 ohms. If it's a D2 each coil should read somewhere around 2ohm. S4 should read around 4 ohms, etc.
If the coil reads 0.000 or crazy numbers jumping around or i once had a VC blow that read 64 kohm, so if it is anything unusual, it is likely blown.
The System :
FREE BOOSIE BADAZZ
0/11 ssssss755
Ok thank you. Appreciate the response!
voice coil ? davidrforbus General Car Audio Discussion & Questions 2 06-02-2010 12:41 PM
Voice coil config newarkbeast973 General Car Audio Discussion & Questions 10 05-10-2010 08:44 AM
Busted voice coil rodpgfx General Car Audio Discussion & Questions 0 05-08-2010 02:49 PM
[SOLD]12" TC-9 subwoofer w/ blown voice coil hobbywerks Broken & Non-working equipment 2 12-30-2009 05:17 PM
Voice coil david in germany (Fix My Speaker) 15 10-27-2009 11:24 AM
