Battery Terminal - Car Audio Classifieds!
Old 06-21-2010, 09:49 PM
brandonb1029's Avatar
FREE BOOSIE BADAZZ
0/11 ssssss755
Default Battery Terminal
Got a question about what type of battery terminal I should look for.
The setup I am going for I will need two 0gauge outputs (1 for each sub amp), one 0guage output to actually power the battery, and one 0-8 gauge output to power the speaker amp.
Each sub will be run with its own fuse holder so I cannot branch off that.
I was looking at new terminals on sonicelectronix site, and most seem to be 3 outputs max, so how should I go about getting 3 0gauge outputs and 1 0-8 gauge output?
Old 06-21-2010, 09:51 PM
toolmaker's Avatar
Mstr of mtl
0/11 sssss2192
Depends.
If you are running a battery with screw in connections, just get you some aluminum or copper bar, drill and tap you some holes and use ring terminals.
If running SAE posts, you can use the clamp on type and add ring terminals to them.
branham1127's Avatar
0/11 sssss2108
Just get a type of battery or battery terminal that will allow you to use ring terminals.
Old 06-21-2010, 09:53 PM
FREE BOOSIE BADAZZ
0/11 ssssss755
Ok, yeah I saw some that had ring terminals, but only had 3 outputs... would I just throw two of the wires on 1 output?
Old 06-21-2010, 09:54 PM
toolmaker's Avatar
Mstr of mtl
0/11 sssss2192
yep
Old 06-21-2010, 09:55 PM
0/11 sssss2108
Should be fine
Old 06-21-2010, 09:57 PM
FREE BOOSIE BADAZZ
0/11 ssssss755
Ok thank you.
Updating the big 3. I need a battery terminal! AuZy_AuDiO General Car Audio Discussion & Questions 3 04-02-2010 05:03 PM
FS: Knu Konceptz Fuse Holder & Battery Terminal MysticStyl3z Wiring, Electrical & Other Installation Equipment 1 03-04-2010 06:58 PM
[FOUND]WTB battery terminal bushing. Violence* Wanting to Buy (WTB) 2 01-11-2010 11:39 AM
Stinger Gold Plated Battery Terminal dropped_tb Wiring, Electrical & Other Installation Equipment 1 10-26-2009 07:49 PM
Triple 1/0 Gauge Battery Terminal... Patrick Simmons General Car Audio Discussion & Questions 9 11-11-2008 10:07 AM
