How Much Port Area - Car Audio Classifieds!
Old 06-21-2010, 10:15 PM
Redrider1's Avatar
0/11 sssssss92
Default How Much Port Area
How much port area would be best for 2 15" Sdc2.5s in an 8-9 cu ft, box, i wanna tune to 34-35 hz, will be putting about 1000 watts on each, in the back of a jeep cherokee, i was thinking 3 6" aero ports but im not sure if that would be enough
Old 06-21-2010, 10:19 PM
0/11 sssss7816
2 6" ports is almost too much IMO
Atomic Loudspeakers
Audiotechnix
Old 06-21-2010, 10:21 PM
I would run 3 6" ports for 2 15's, it was perfect for my 2 15's
Old 06-21-2010, 10:27 PM
0/11 sssss7816
with 3 6's each would need to be 20 inches long
3 yields a vent mach of .05
with 2 6's each would need to be 12 inches long
2 yeilds a vent mach of .12
Atomic Loudspeakers
Audiotechnix
Redrider1's Avatar
0/11 sssssss92
i know the 12-16 sq in of port per cu ft of box is a rule of thumb for slot ports, but i heard aeros require less overall port area with the same or greater db output and 3 6"ers would only be 85 sq in, and the rule would be about 108-144 sq in for a 9 cube box
0/11 sssss7816
Atomic Loudspeakers
Audiotechnix
Old 06-21-2010, 10:41 PM
Redrider1's Avatar
0/11 sssssss92
of heard of 2 of the 15s with 4 6" aeros in a 9 cube box doing well on the meter, but i just dont think 2 of the ports would be big enough to get the most out of them because thats only 57 sq in of port, which does not sound like very much
Old 06-21-2010, 10:45 PM
Redrider1's Avatar
0/11 sssssss92
how long were they and for wat size box tuned to wat
Old 06-21-2010, 10:49 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Generally speaking, 7^2ish port/cube when using aero's.
Old 06-21-2010, 10:51 PM
my box was tuned to 37hz but box was 7ft
port area too big? dylan9999 General Car Audio Discussion & Questions 6 05-06-2010 12:14 PM
help me with port area jwesenick79 Enclosure Discussion & Design Construction Help 5 01-08-2010 12:22 PM
Enough Port Area worstenemy453 General Car Audio Discussion & Questions 13 10-02-2009 07:34 PM
How much port area? DeadlySones Enclosure Discussion & Design Construction Help 15 07-22-2009 11:45 AM
