New problem in my cobalt. - Car Audio Classifieds!
Old 06-22-2010, 02:24 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default New problem in my cobalt.
I can barly get the car started now? IDK WTF is goin on with this pos. My door speakers won't play either. Usually i get this whining noise outta them even when the music is off now i dont even get that.
Old 06-22-2010, 02:26 PM
0/11 sssss5305
alt dead, batt dead, fuses blown? You gotta give more info then "barely get it started"
Old 06-22-2010, 02:28 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
whats your battery voltage at?
Originally Posted by Anthony VerticalScope
I personally don't give a shit what avatar you use.
and MiX and fatpat are valuable members of society? i dont thinks so. lol
i expect nothing less from a worthless piece of shit like yourself.
Old 06-22-2010, 02:29 PM
0/11 sssss6030
I turn the key and it sounds like it's skipping. I'm not sure if its the sparksplugs or what. And the voltage on my voltmeter does some weird thing. It'll jump to 13.xx then drop to 11.xx and when i get the car finally started right the voltage is around 15 volts witch is fine. The car drives normally other than the power steering.
Old 06-22-2010, 02:31 PM
0/11 ssssss852
Is it sound like an electrical noise or an engine noise? if electrical could be your starter going out.
[SIGPIC][/SIGPIC]
140.9db @37hz w 2 10" on 1500w
AQ Nuthugger
car audio is the new drug bro!!! F*ck with this and you go broke!!
wat they dont know is that real ballers run AQ
wait wats AQ?
JL's mean stepdad
0/11 sssss5305
skipping as in misfiring or the starter not spinning the motor over cleanly?
Could be as simple as a bad ground or corroded batt cable.
0/11 sssss6030
Im not sure the voltmeter says 15.xx when the car is on.
Old 06-22-2010, 02:35 PM
0/11 sssss6030
I got everything back to stock execpt my door speakers and my 4 channel amp. I just put on a kun 1/0 from the alt. and the cable is fine.
It's like the engine will kinda start but then it's like it's not getting enough gas or something and it'll start sputtering and shaking. The RPM's will barly go over 0 and gets no where near 1000. Hope that explains it.
0/11 sssss1904
Feedback Score: 22 reviews
prolly some fukcked electrical
Old 06-22-2010, 02:36 PM
0/11 sssss6030
Definatly engine.
cobalt getting down GODHATESCIVICS Car Audio Videos 19 06-24-2010 02:39 AM
alt for a cobalt? scott s General Car Audio Discussion & Questions 4 06-21-2010 04:23 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
kicker cobalt davidrforbus General Car Audio Discussion & Questions 8 04-18-2010 10:02 AM
Question for kicker cobalt or anyone who has a cobalt. davidrforbus General Car Audio Discussion & Questions 7 04-15-2010 01:28 PM
