Help!! Battery for 05' Monte Carlo - Car Audio Classifieds!
Old 06-22-2010, 02:48 PM
dag79's Avatar
0/11 sssssss64
Default Help!! Battery for 05' Monte Carlo
Hi,
I'm getting a 270A alt. from Mechman for a 2005 Monte Carlo LS. I wanted to know what battery can I use under the hood as my primary? The setup will be daily driving only, I want to avoid getting a a secondary battery in the trunk due to space restrictions. I will have a total of 3200 watts. What do you recommend for me?
Thanks,
dag79
Old 06-22-2010, 02:59 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
i think you can fit a d3400 or s3400 up there. or you can modify your battery bay to hold a bigger one.
go measure and let us know how much space you have
Originally Posted by Anthony VerticalScope
I personally don't give a shit what avatar you use.
and MiX and fatpat are valuable members of society? i dont thinks so. lol
i expect nothing less from a worthless piece of shit like yourself.
Old 06-22-2010, 03:51 PM
0/11 sssss1016
^^^ Correct the 3400 is the direct replacement, but if you have some extra room you can fit the D6500. It is just a little wider and longer.
'1.888.497.7693 x1211
Old 12-09-2010, 04:31 PM
dag79's Avatar
0/11 sssssss64
True. After checking the tray dimensions, I'll only have enough for the D3400 for my main. What do you recommend running as a secondary?
Old 12-10-2010, 09:04 AM
0/11 sssss1016
You could run another 3400 in the back or step down to the 1200 in the back. Depends on the room you have to work with.
Monte Carlo Knights Crest dag79 General Car Audio Discussion & Questions 0 06-15-2010 09:23 AM
nothin special... 98 Monte Carlo Fatboy501 Member Rides & System Pictures 13 05-20-2010 08:49 PM
270A Alt. for 2005 Monte Carlo dag79 General Car Audio Discussion & Questions 1 04-20-2010 09:31 AM
Monte Carlo 2 btl 15s. got160s? Car Audio Videos 20 03-23-2010 06:26 PM
