amp fan noise - Car Audio Classifieds!
Old 06-23-2010, 11:09 AM
0/11 ssssss153
Default amp fan noise
so on my rubicon 1600d i was noticing lately when i first start my vehicle( after it being off for 30 mins+) my amp is really loud for about 10-15 seconds and its getting even louder now when i first start my vehicle, it sounds like the fan im thinking? if it is should i be concerned? it goes away after 10-15 seconds but is getting really loud lately.
Old 06-23-2010, 11:44 AM
ampjunkielikeme's Avatar
GOT AMPS ?
0/11 ssssss381
Feedback Score: 17 reviews
im pretty sure that the fan inside your amp is cooling the audio driver board. it gets pretty hot under normal operation, and after a while the fan will start to deform from the heat and start making annoying noises. it will eventually stop working all together. this will cause the driver board to overheat and cause damage. you don't want that.
you can buy a new fan on ebay for cheap . just measure it and make sure you get the right size. it should be really easy to replace without taking the board out of the heatsink.
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
port noise ellocojorge General Car Audio Discussion & Questions 26 05-24-2010 03:45 PM
Amp Noise mythyone General Car Audio Discussion & Questions 0 04-21-2010 09:29 PM
fan noise gbo559 General Car Audio Discussion & Questions 1 12-28-2009 01:52 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
