amps problem!! - Car Audio Classifieds!
Old 06-23-2010, 07:25 PM
newarkbeast973's Avatar
0/11 sssss7810
Default amps problem!!
equipment
amps
sundown 3000d & 100.4D
electrical
xs d925 front
xs d1200 rear
big 3
dcpower 275ah alt
all my rear equipment was recently moved to the spare tire location.
the situation. I was crusing with my gf and son in the car so the volume was at like 5-8 on the HU. Then out of nowhere it stops playing music!!
I get home thinking that the amps may have gotten hot so I took out my box, carpet, plywood floor board to check the amps. amps were hot but not like burning.. Let them cool down as I started checking all my fuses and wire connections and voltage of batteries. everything seem to be good. turn the car on and amps dont even turn on!!! what could it be!!
New build coming soon!!
Old 06-23-2010, 07:27 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
remote turn on lead
who wants a nudel ride?
Old 06-23-2010, 07:28 PM
0/11 sssss2351
h/u
4 15" Audiopulse Revos
2 SAZ3k's strapped @ 1 ohm
7 stinger Spv70 batts
1 Iraggi 300 amp alt
Old 06-23-2010, 07:31 PM
brandonb1029's Avatar
FREE BOOSIE BADAZZ
0/11 ssssss755
Don't know how similar to Hifonics amps but heres some stuff they have in their manual.
Amplifier heatsink overheating
The amplifiers will shut down when the heatsink temperature reaches 80 degrees centigrade, and turn back on once the unit has cooled down below that point.
Causes of overheating:
1 - Inadequate cooling - relocate or remount to provide better natural airflow over the fins.
2 - Driving high power levels into low impedances - back off on the volume control, and/or make sure you are not loading the amplifier with less than the
recommended loudspeaker impedance.
3 - Excessive voltage drop can also cause overheating.
System does not turn on
1 - Check all fuses.
2 - Check all connections.
3 - Measure the +12 volt and remote turn on voltages at the amplifier terminals. If these are non existent or low, take voltage measurements at fuse holders,
distribution blocks, the head unit’s +12 volt and remote leads to localize the problem.
4 - If the HIFONICS lettering is illuminated but you do not have Power or Protection illuminated, simply remove your remote wire and use a jumper wire from 12V+
on the amplifier to the Remote connection on the amplifier. If the amplifier powers on like normal then you do not have adequate voltage/amperage from your Remote
source to turn your amplifier on. You will need to seek out a certified installer to install a relay for your amplifier. If the jumper does not power your amplifier on, you
may have internal damage and should contact Hifonics Customer Service to locate an Authorized Repair Center.
Old 06-23-2010, 07:32 PM
Im an Investment!
0/11 ssssss450
check remote wire
Team D.O.A.
Old 06-23-2010, 07:34 PM
0/11 sssss7810
Originally Posted by CHAOS_THEORY View Post
remote turn on lead
the wire is still in the amps
Originally Posted by Parker G View Post
h/u
what can be wrong with the HU? I can see the time going by on the music. dont know if that means anything
FREE BOOSIE BADAZZ
0/11 ssssss755
This may seem stupid, but you said you checked your wires, did you pull on them a little too? I know once my wire split through but stayed together until I pulled with a little force it seperated (on the ground).
Also, if any of the wire is burnt, try cutting those parts off and reconnecting all wires.
You can always check your power wire by seeing if it sparks... not sure about ground, it just won't turn on if the ground is not connected. Remote wire, maybe it came loose on the H/U... can try running short wire from power to remote and seeing if it works then, then it likely came lose or something.
Old 06-23-2010, 07:43 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
what i meant is this, check it for shorts or interrupted connections,..
or like parkerg suggested, the h/u,... remote turn on lead may have shorted out internally,... ive had receivers that have done that
Old 06-23-2010, 07:57 PM
0/11 sssss7810
how can I check that?
Old 06-23-2010, 08:27 PM
FREE BOOSIE BADAZZ
0/11 ssssss755
Short Wire from Power On Amp to Remote On Amp
If it works, well you found the problem.
I have a problem. hornedfrog1985 Off Topic Chat 33 05-07-2010 12:53 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
95 Infiniti q45, 2 amps, 4 gauge, added batt, on 3rd alternator... whats the problem? hollatchaboy General Car Audio Discussion & Questions 4 01-27-2010 10:20 PM
I want a new amps/amps, any budget reliable suggestions?? .5-1ohm?? Vaginatarian General Car Audio Discussion & Questions 47 12-14-2009 11:38 AM
[SOLD] zed audio made boss amps. 2 ch/4 ch sleeper amps! ampjunkielikeme 2-Channel Amplifiers 2 09-04-2008 05:25 AM
