anybody have a wiring diagram - Car Audio Classifieds!
Old 06-25-2010, 10:39 AM
Captain Tying Knots
0/11 sssss1220
Default anybody have a wiring diagram
for a quad voice coil sub to wire it to one ohm?
Old 06-25-2010, 10:43 AM
0/11 sssss2011
Feedback Score: 61 reviews
Rockford Fosgate - Woofer WiringWizard
Old 06-25-2010, 10:51 AM
Captain Tying Knots
0/11 sssss1220
Originally Posted by fasfocus00 View Post
that doesnt help they only have single and dual
Old 06-25-2010, 11:03 AM
0/11 ssssss337
ur making it too hard on yourself. treat it like it is 2 dvc 4ohm subs.
wire 2 vc parallel. then the other 2 parallel. then run those two groups parallel.
JL Audio - Car Audio Systems
look at the 2 dvc 4 ohm subs. treat each sub like 2 vc on your own sub.
Old 06-25-2010, 11:05 AM
0/11 sssss2011
so 2 dual voice coil woofer don't have similar wiring configurations as a single quad voice coil woofer? (2x2≠4)
maybe next time I should really be of no help and just give you the formula for Ohm's Law
Old 06-25-2010, 11:13 AM
0/11 ssssss316
Captain Tying Knots
0/11 sssss1220
well no because they guy i bought it from said wire it to one ohm and you cant with 2 2 ohm subs
Old 06-25-2010, 11:14 AM
0/11 ssssss316
Or check out the TC website for more options
TC Sounds (TC-5200)
0/11 ssssss337
E = I R
Voltage = Current x Resistance
E Voltage applied to the circuit, in volts (V) I Current flowing in the circuit, in amperes (A)
R Resistance in the circuit, in ohms
your gonna have to find out your voltage and Amperage your draw. then divide the voltage by the amount of amperage you draw. Shouldnt take more than an hour to figure out. Or you can just look at the picture we gave you.
Old 06-25-2010, 11:34 AM
0/11 ssssss337
so this is a quad 2 ohm? since u didnt specify i was guessing 4 ohm. if its 2 ohm you cant get 1 ohm. Youve got 8, 2, or .5 ohm. thats it
system diagram Ricoshay General Car Audio Discussion & Questions 6 03-29-2010 12:06 PM
diagram for wiring 4 channel amp to mids and highs Ccab81 General Car Audio Discussion & Questions 0 01-12-2010 07:27 AM
Stinger SVMB wiring diagram gbo559 General Car Audio Discussion & Questions 1 12-04-2009 07:14 PM
I need a wiring diagram mytyeerinpie General Car Audio Discussion & Questions 28 04-11-2009 04:36 PM
Need a wiring diagram i can help splvictim20 Miscellaneous Stuff For Sale 6 01-29-2009 11:41 PM
