HELP! - Car Audio Classifieds!
Old 06-25-2010, 08:06 PM
0/11 sssss1435
Default HELP!
so today when i got out of work i got into my car to listen to music. but when i start my truck the headunit doesnt come on. i try turning my car off and on and when it still doesnt work i remove the face. i notice that the unit still has power, can rotate the face (Kenwood xxv-01D) and eject CDs. I hit the reset button and the unit comes back on for about 30 seconds before turning off again. when i finally manage to keep the unit on by once again resetting it i think everything is fine. until the music starts to skip like i am listening to a CD. even though my ipod is hooked up through the aux port. i try taking the unit out and reconnecting the harness. it doesnt help and at this point i am also getting static like i am listening to a radio station that isnt coming in clear. what is the problem? and how do i fix it? thanks
I would like my signature back please ant. I don't appreciate it being changed.
Old 06-25-2010, 08:25 PM
0/11 sssss1435
anyone?
Old 06-25-2010, 08:30 PM
0/11 ssssss337
sounds internal to me. Something that transmits signals into actual signal that goes through the speakers is messed up. Hit any big bumps? May have rattled something loose.
Old 06-25-2010, 08:32 PM
0/11 sssss1435
nothing that i can think of. think heat could have done it? it was around 85 today and was sitting in my closed up truck for around 5-6 hours
Old 06-25-2010, 09:28 PM
0/11 ssssss337
doubt it. I live in GA and its 100+ every day and my POS dual doesnt even mess up. except in cold weather. then it skips cds but thats it.
Old 06-25-2010, 09:31 PM
Old skool junkie's Avatar
DTD
0/11 ssssss712
Feedback Score: 22 reviews
Check the ground wire itself? Make sure it's getting a proper ground, and if not then (as stated above) it might be internal. I'd start there though
SQL?? One or the other folks, make up your mind already!
Don: Surfer, you are a really well known SPL box builder - how do you make a box sound REALLY loud?
Surfer: You taketh the cardboard paper towel roll, you cutteth said roll longways, you tapeth said cardboard to the boxeth.
Old 06-25-2010, 09:40 PM
0/11 sssss1435
Yup the ground is good. I was having some issues with the stock hu ground so i found another one near my shiftong column. Only reason i dont think i jarred somethong going over a bump is because it was fine when i got to work where it sat all day and when i went to leave was when the issue started
Old 06-25-2010, 09:43 PM
0/11 ssssss337
something may have been loose. then shorts periodically when power is sent to it. I know when i installed my HU i left some wires uncovered and it would short out when i would turn left when they touched then come back on once I stopped turning.
Old 06-25-2010, 09:48 PM
0/11 sssss1435
Alright thanks. Ill try taping over or crimping my loose wires in the morning
Old 06-25-2010, 09:52 PM
0/11 ssssss337
I suggest going very heavy on the electrical tape. If that doesnt work it has to be internal.
