Why are my two Alphas louder with the ports sealed off? - Car Audio Classifieds!
Old 06-26-2010, 11:42 AM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Default Why are my two Alphas louder with the ports sealed off?
I've got my two alpha 15's in 4 cubes each separate chambers with a single 6" X 11" aeroport in each chamber. When just playing music ANY lower note sounds terrible, it's like not sound at all it's just sub moving. When i shove a towel in the port it hits the lows better and the highs are louder...
What is wrong with my tuning? I was told that a 6 inch diameter aeroport (11 inches long) in 4 cubes would be roughly 36hz. Am i THAT far off? Trying to get it worked out today... second day of scrapin.
Fo eights in da pickup!
Old 06-26-2010, 11:43 AM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Also i heard that you need at least the diameter of the port away from the back wall (so 6" away from the back of my box) for it to be accurate. Mine isn't, it's maybe 2-3 tops. How bad would that change things?
Old 06-26-2010, 11:46 AM
0/11 sssss6061
When you "seal it off" it probably gives it a chance to actually play those lower notes. When you have the port normal it's tuned too high to hit the lows. Try tuning like 30-32hz, and you will love it.
Old 06-26-2010, 11:56 AM
TEAMLOWPOUNDERS
0/11 sssss3564
Seince you aero port is in the box now try having it stixking all the way out of the box...if that doesn't work try tuning lower like horned said
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 06-26-2010, 12:36 PM
0/11 ssssss798
yes having it 2-3" away from the back will def. effect it.. thats to close for comfort, can probably get away with 4", but no less... try making something like a speaker ring, and mount it behing the port mount, so the port is extended from the box... use like 2-3 pieces of MDF, that will give you an extra 1.5-2.25"
Getlikeme:remote start
REFS: (from CA.com)Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle, mlstrass , Mazzasec, SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic meade forum. Team_Psi reconed SSX, Timmy13091 sold Deka Battery,
Old 06-26-2010, 01:11 PM
0/11 ssss31255
With so many variables it's hard to tell you what's really going on.{is your tuning correct?}{if your aeroports are 11" from flare to flare or flare to cut end, you might actually be tuned at 38hz or even higher}
[props to the original poster of this depiction on another forum]
If your box is tuned at 36hz, it will not be very efficient below 30hz. If the music you are playing is hitting 30 hz and below, even if you tuned at 30hz, it will still be louder sealed.
The simple truth is that sealed enclosures are better suited for frequencies less than 35hz.
Ported enclosures put up louder numbers at frequencies above 35hz.
Another issue is your subsonic filter setting. I recommend setting it 5hz below your tuning frequency.
it's ok to like it as a sealed box.
You may want to seal it in a way you can remove the block offs in the event you find a TL to play with.
Old 06-26-2010, 01:13 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Did you measure the tube or the overall port? Also give your port breathign room!
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 06-26-2010, 01:18 PM
0/11 sssss6061
Not sure I really agree with that.
Old 06-26-2010, 01:25 PM
bobbygilly's Avatar
Owner of UE
0/11 sssss6562
Feedback Score: 23 reviews
i also tune 30 - 32 hz 31.96 right now with the current box
love it and i will never go back to higher tuning
Old 06-26-2010, 01:29 PM
1coolrt's Avatar
0/11 ssssss338
How's ur box built like? Subs up ports to the back or all firing back toward trunk?
My sounds are quiet lika cricket piss... =P
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 03:09 PM
Box for alphas BassJunkie General Car Audio Discussion & Questions 1 11-10-2009 11:23 PM
box for 2 15 alphas kingmade08 Enclosure Discussion & Design Construction Help 0 11-08-2009 10:28 PM
Simple question - ports up or ports forward? FatBoy2 Box Requests 20 09-21-2009 04:45 PM
Any tricks to louder sealed up? aturcotte127317 General Car Audio Discussion & Questions 49 08-05-2009 04:05 PM
