Is this ok? - Car Audio Classifieds!
Old 12-30-2008, 07:31 PM
MysticStyl3z's Avatar
0/11 ssssss113
Default Is this ok?
If you didn't read my thread about the problem i'm having, i have a 15" RD sonance and a RD 1750. I'm not getting the right amount of output i should be and i'm still trying to figure out what's wrong. I'm wondering, would it be bad if i left the sub in my car with the gain about 1/4-1/2? Is it alright for me to listen to it like that even with little output or could it be messing something up? I'm probably going to get a new battery soon and hope that will help, and if not i'll just save it for a different car i should be getting in a few months.
thanks.
oh here...the other thread... Got some problems
Old 12-30-2008, 07:39 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
No way to tell. Did you try turning the gain past 3/4 just to see if it got loud or not? There is clearly something wrong with that setup somewhere. Either bad/ partially blown amp or bad/blown sub.
My Car, My Ears.
Old 12-30-2008, 10:06 PM
0/11 ssssss113
yeah i tried turning it up pretty far...it keeps getting louder as i turn even past 3/4. i just wish i was a bit more experienced so i could troubleshoot this easier haha.
Old 12-30-2008, 10:16 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Do you have a DIMM?
Check the final resistance of the sub all wired up and make sure it is correct, If possible try a different amp with that sub and also a different sub with that amp. This should help you to figure out which one is the problem.
Also I know everyone said check your wiring in the other thread but check it again and don't forget your RCA's, swap them out for a set you know is good.
/ CAAA Member #2 /
Old 12-30-2008, 10:42 PM
0/11 ssssss113
Originally Posted by SPY View Post
Do you have a DIMM?
yes i have a dmm and the resistance is fine. i will put my CVRs in there tomorrow and see what happens. and my RCAs worked fine with my old setup so i dont know how they could be bad now. and i dont have another set anyways. could it be my battery?
Old 12-31-2008, 04:17 PM
SPY SPY is offline
0/11 ssss10192
I could be the battery but I would think you would notice other problems if the battery was the issue.
Put your DIMM on the battery and see what it's resting voltage is.
/ CAAA Member #2 /
Old 12-31-2008, 04:50 PM
No, I'm not dead
0/11 sssss8128
Check your voice coil phase...
