need a lil help never done this before - Car Audio Classifieds!
Old 01-02-2009, 12:16 AM
waresgaragestereo's Avatar
Active Member
0/11 ssssss787
Default need a lil help never done this before
i have tried to make this door pannel and i think ive succeeded. how do i mount it to the door. i traced the existing door pannel on a piece of wood and cut it out and now i need to mount it. please help me.
Zach Ware
Making things loud, its what I do.
DO NOT ORDER FROM AUTOPARTSGIANT.COM
Old 01-02-2009, 12:43 AM
0/11 sssss1560
some pics of the door would help. without seeing it i'll refer to my door. Around the edges there are screw holes. I would transfer the placement from the original panel and then attach it that way. Any help?
Old 01-02-2009, 12:51 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
Screws, or bolts should do the job but its hard to see what your talking about with out pics
Old 01-02-2009, 01:42 AM
silvercookie's Avatar
0/11 sssss1945
should have just worked on your old door.
wont be a pain in the ass to find all the clips and screws and such.
Old 01-02-2009, 01:46 AM
0/11 sssss1560
your limited if you do it that way. my plan is to cut a hole for the door latch and reuse that piece and relocate the rest
Old 01-02-2009, 02:47 AM
Prohibited Sellers/Buyers
0/11 ssssss327
post up some pics.
If the new piece is big enough or has the right spots...you could just screw it from the backside of the door
Old 01-02-2009, 07:32 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Epoxy.............. sike.
Could just pre-drill and use some taps in the door then use those to bolt up the panel.
My Car, My Ears.
Old 01-02-2009, 09:12 AM
Active Member
0/11 ssssss787
thats my idea too
Zach Ware
Old 01-03-2009, 02:08 AM
0/11 sssss1560
tell me how it works out, post pics!!!
make it easy 4 me when i do it
Old 01-03-2009, 02:23 AM
KOVEMASTER559's Avatar
Active Member
0/11 ssssss776
make plastic clips/fasners with hot glue then lay some epoxy to them and make a drill hole to existing panel. works like a charm and cant see no bolt/screws.
http://i3.ebayimg.com/01/i/04/74/f7/e8_2.JPG
