Question about 18v setup - Car Audio Classifieds!
Old 01-03-2009, 12:05 PM
0/11 sssss1418
Default Question about 18v setup
If I went to autozone, and got a single 6V battery, and wired that in series, I would end up with a 18V final load right?
What could I do after that?
Im trying to run 18V on a budget.
2005 Chevy Colorado
Pioneer Avic N1
Viper 791 XV Remote start/Security
PG RSD 6.5'" components
Kicker Hyperflex 0 Gauge
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
:CA.COM:memphisflex,iamamp3pimp, twistid, grimreper912003,Wkbdkid, csu87,1000101, mrwigglezdj,Goindef154
ROE: abmw735ie32, southpole1989, tacosys,Breakjunki, groundpound4200, Visitor
CAC.O: Caps, banginexplorer, tzsplfocus, jagblazer01, Mojo, lunari, Ctippins,duece212, derrick824, BlackWaterOP
Old 01-03-2009, 12:16 PM
0/11 sssss1230
No, that would rest around 19v and charge much higher.
You would want to add 4v to a 12v setup. Best method is cyclon BC cells.
Team Excessive
Old 01-03-2009, 12:18 PM
0/11 sssss1418
ok so how could I get ahold of said 4v batteries..and if I want to add more what volt do I add?? more 4V but wired in parallel?? or 12V wired in parallel. or do I just dont add anymore and hook up the system to the single 4V battery.
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 01-03-2009, 12:31 PM
The A Team's Avatar
Active Member
0/11 ssssss817
Read this.
16+ Volts How To/Pros/Cons? - Car Audio Classifieds
Old 01-03-2009, 12:33 PM
0/11 sssss1230
You generally want the same amp hour rating of 4v as your 12v. but if its just for burps 2-4 sets of BC cells would work. the bc cell is 2v so you would need 4-8 of them.
no safe and cheap way, though i have seen things i wouldn't do myself.
Team Excessive
Old 01-03-2009, 12:34 PM
0/11 sssss1418
what if its for daily
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 01-03-2009, 12:51 PM
Biggy's Avatar
Loyal Member
0/11 sssss2240
how you think you could charge em in a daily setup?
If you hear any Clipping, it may be your Ears or the Coils hitting the End Stop
Sundown Audio Germany
Hey, what can I say? I love me some poonanner. Even if I have to hit them with a door and handcuff to the chair.
Old 01-03-2009, 12:56 PM
0/11 sssss1418
wit mah gerbils?
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 01-03-2009, 12:57 PM
0/11 sssss1418
This one guy said use a mla module for a stock alt..
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
My quest to have the best used setup in the world!! tahoebrotha Build Logs 36 01-06-2010 02:10 PM
Full Camera and DVR setup. Anotherguy Miscellaneous Stuff For Sale 7 01-13-2009 04:30 PM
New here, so i thought i would post pics of my setup Cage Member Rides & System Pictures 13 11-30-2008 03:45 PM
help building PA setup. RollerDJ Off Topic Chat 10 11-26-2008 06:38 PM
New Setup! mazda6i07 General Car Audio Discussion & Questions 8 11-17-2008 10:09 AM
