The Easy Performance V-Booster - Car Audio Classifieds!
Old 01-05-2009, 07:30 AM
0/11 sssss1560
Default The Easy Performance V-Booster
The Easy Performance V-Booster safely raises the voltage of your factory alternator system by .6 volts. The stage 2 kit raises alternator voltage by 1.2 volts. Installs in seconds by plugging inline with your alternator's voltage reference line. Innovated, designed and manufactured by Easy&ZZ Performance.
Grand Am --- ZZ Performance
Plugs between car and alt. Looks to me that it just has a resistor inside to lower the reference voltage.
Right?
Old 01-05-2009, 07:35 AM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
this is confusing but i think i get it. Anyone ever tried it.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 01-05-2009, 07:41 AM
0/11 sssss1560
Its like doing the same thing but instead of feeding the alt a lie, it makes it do more at the same voltage.
Old 01-05-2009, 08:48 AM
0/11 sssss1560
maybe i explained the problem poorly.
my car doesnt make pwr at idle so im trying to figure if this is better than an overdrive pulley or vice vs
Old 01-05-2009, 08:49 AM
Veteran Member
0/11 sssss4401
couldnt this burn up your alt.
Sub: ---
Speaks: ---
Headunit: ---
Old 01-05-2009, 08:50 AM
0/11 sssss9745
... and you are trying to keep stock alt? Not sure how safe that device would be with a high current system.
I would just invest in a ho alt.
Old 01-05-2009, 08:51 AM
0/11 sssss1560
i have a "ho" alt. spent 200 for it at a local generator place. problem is if i let it idle long enough i get a abs light the comes on, the thing is if i keep my rpms up (D instead of overDrive) it never comes up. so overdrive for more at idle or volt boost for better bat charging, both?
Also isnt that part just a resistor?
Old 01-05-2009, 08:58 AM
Veteran Member
0/11 sssss4401
just change pulleys??
Sub: ---
Speaks: ---
Headunit: ---
Old 01-05-2009, 09:03 AM
0/11 sssss9745
That could help. I've heard of people using smaller pulleys (but not too small)
Also, that's what happens with some of the ho alts that are out there. That's why I support Mechman and speak so highly of them, their alt give off high output even at idle but do cost a little more (but you get what you pay for).
Old 01-05-2009, 09:06 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Adjust idle?
My Car, My Ears.
Tags
alternator voltage
Raising alt voltage the easy way. DLP customs Tutorials & Quick References 0 01-04-2009 12:45 PM
performance teknique alex95sl2 Bargain Bin 6 12-18-2008 03:41 AM
Volkswagen Super CC Performance Concept Patrick Simmons General Automotive Chat 3 11-10-2008 10:32 PM
How to get a girl, 9 easy steps bumpin buick Powder Room 5 09-04-2008 06:49 PM
