Wiring - Car Audio Classifieds!
Old 08-14-2008, 01:31 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Default Wiring
well i need to make sure im wiring it right, but im pretty sure Forceww got it down but just want a 2nd opinion
my MA Audio amp does [email protected], i cant bridge cause that puts out alot more power(2400watts)
my subs are Dual 2s
how will it be wired?
LINK #1
http://akamaipix.crutchfield.com/ca/..._2-ohm_2ch.jpg
LINK #2
http://akamaipix.crutchfield.com/ca/...2-ohm_mono.jpg
or if you can, make a quick Paint job of the wiring, any help is appreciated
also here's my amp
http://ampguts.realmofexcursion.com/MA_5082HX/
92 Ranger Walkthrough
(Under Construction)
Old 08-14-2008, 01:37 AM
0/11 sssss2351
Default Re: Wiring
Here's a better place to do wire diagrams http://www.rockfordfosgate.com/rftec...2&woofer_imp=3
4 15" Audiopulse Revos
2 SAZ3k's strapped @ 1 ohm
7 stinger Spv70 batts
1 Iraggi 300 amp alt
Old 08-14-2008, 01:40 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Default Re: Wiring
yeah thats a lil cleaner lol
i was just thinking i needed to wire like that but instead of 2 wires i need to run 2 more into the 4 holes, cause 2 only makes it bridged
but i might try it out on 2 ohm bridged, running the 2400watts
Old 08-14-2008, 01:42 AM
0/11 sssss2351
Default Re: Wiring
What equipment are you using?
Old 08-14-2008, 01:46 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Default Re: Wiring
2 custom 15s, take 2k daily each
the amp listed in 1st post at the bottom
Old 08-14-2008, 01:48 AM
forceww's Avatar
0/11 sssss3264
Default Re: Wiring
Im tellin ya man. If those things take 2000 rms if you run em at anything but 2 ohms bridged they aint barely gonna move lol
ANOTHER New System
Team SBC-Team CACO-Team Lethal Beatz
plenty of refs just ask
Old 08-14-2008, 01:49 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Default Re: Wiring
well rms is between 1k-2k
but woofercooker said no more than 2k max
so i guess 1k should be good, but my electrical just bothers me
Old 08-14-2008, 01:51 AM
forceww's Avatar
0/11 sssss3264
Default Re: Wiring
With your 1/0 wiring and only running them at 2 ohms youll be fine. Like I said your voltage is gonna be lower until you can put in some extra batts/alt but its gonna be nothing to worry about. What kind of car is this going in anyways i forgot
ANOTHER New System
Old 08-14-2008, 01:53 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Default Re: Wiring
check the avatars lazy
99 4dr blazer
Old 08-14-2008, 01:55 AM
forceww's Avatar
0/11 sssss3264
Default Re: Wiring
man its 3 in the a.m. lol. It looks like your car has a stock 100 amp alt if im not mistaken. So im tellin ya. With your 1/0 and at only 2 ohms. You should be just fine
ANOTHER New System
Battery & Wiring help jagblazer01 General Car Audio Discussion & Questions 5 11-02-2008 03:53 PM
Wiring, where to buy and what brands? SPY General Car Audio Discussion & Questions 14 10-16-2008 10:24 PM
Wiring Ohm Loads bumpin buick Tutorials & Quick References 3 09-03-2008 12:42 PM
Re: Wiring forceww Recycle Bin 0 08-14-2008 02:03 AM
MOVED: Wiring forceww Recycle Bin 0 08-14-2008 01:56 AM
