Trunk lock??? - Car Audio Classifieds!
Old 01-12-2009, 12:03 PM
0/11 ssssss397
Default Trunk lock???
Ok guys so what I have spent the last hour or two searching online for is a trunk lock kinda thing....yea i know very descriptive. Some cars come with these stock its right down by the drivers feet and you have to use a key to unlock to trunk. What im looking for is something like that. That way if someone were to break into my car they would need the key to unlock trunk.
My car is a 1998 Mercury Sable incase you need to know. Also some people just cut the wire I dont really want to go that route. Thanks for any and all help!
Links would be helpful also.
Old 01-12-2009, 12:49 PM
natisfynest's Avatar
0/11 sssss1505
or they could cut the cable and yank on it and pop ya trunk like they did my honda
Old 01-12-2009, 12:53 PM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Does your car use a cable or is it electric? If it's cable then I recommend removing that and adding a electric solenoid to open it. Then you either hide the button or make it ignition controlled or both. The electric trunk solenoids are only like $10.
Old 01-12-2009, 12:56 PM
0/11 sssss1505
this is what your looking for type in honda trunk release
Old 01-12-2009, 12:59 PM
0/11 sssss1505
shit yours is electric just reroute the wires to a diff place that would be easy enough
Old 01-12-2009, 01:33 PM
Derrick824's Avatar
0/11 sssss2362
That's what I was thinking but wasn't sure if they were electric.
Old 01-12-2009, 02:34 PM
0/11 ssssss397
Shit I had no clue there were electric ones and ones with wire lol. Now im not good this kinda stuff so how do you smart ones suggest I reroute it, and where to?
Old 01-12-2009, 04:15 PM
0/11 sssss1505
thats up to you to decide not in the glove box or center concole i would hide it under the dash somewhere or if you have a button on your dash you dont use wire it to that so it looks like something else
Old 01-12-2009, 04:43 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
wire it just under the seat were it can't be seen, but just within reach of your fingers.
Proud Member of CAAA!
Old 01-12-2009, 05:01 PM
0/11 ssssss397
I like this. Now to browsing the interwebz for the switch or whatever it is I should use.
Thanks everyone!
Patrick's CACO amp rack and trunk panel ideas Patrick Simmons Enclosure Discussion & Design Construction Help 31 01-18-2009 05:19 PM
Sealing off the trunk? mazda6i07 Enclosure Discussion & Design Construction Help 51 10-23-2008 07:07 PM
USACi Sanctioned Event - In The Trunk ~ BEAUMONT TX ~ 10-04-2008 Patrick Simmons Car Show Feeds 0 09-29-2008 02:05 AM
Lock topic? forceww Announcements - Suggestions - Feedback - Support 3 08-09-2008 05:16 PM
