9V Batteries, Are they harmful? - Car Audio Classifieds!
Old 01-18-2009, 03:30 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Default 9V Batteries, Are they harmful?
Well, I was sitting here bored out of my mind because everyone got off MSN and nobody was texting me back, so I was lookin around and found an old 5.25" door speaker, and thought to myself..... "Why not try and blow this up?"
I have heard before that using a 9V battery to "pop" a speaker in your car is bad and shouldn't be done for more than a split second or you can blow them.
So I grabbed a bunch of 9V batteries (8) and wired them up in series. So I'm sitting here with 72V and a 4ohm speaker and turn on my phones camera, and all it does is pop when I hook it up. So I held it for a little, popped it a lot, the copper was actually kind of burning from the voltage (green sparks instead of blue) And after about 2 or 3 minutes I gave up. The coil was just mildly warm and gave off the slightest bit of smell. The batteries would almost burn you to touch them. If you pressed on the cone it still moves freely and makes no noises.
So I have concluded that using a 9V battery to "pop" a speaker in a car to find out which one the wires go to is not deathly harmful for them.
Thought I would share that with everyone.
Team CACO Team SHOK
Supporting Member
Old 01-18-2009, 03:41 AM
No, I'm not dead
0/11 sssss8128
72V yes but very, very low amperage. V*A/Ohms = W. It's called Ohm's law and determines the actual working wattage. If you wired a bunch of sub C batteries together and did the same thing you'd burn the speaker up in a hurry. Sub C's have enough amperage to jump start a car. I've seen it done first hand.
Old 01-18-2009, 04:08 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Yeah, It was mainly just to show that the people who say that a regular old 9V battery will blow a speaker are wrong.
Do you happen to know the amperage of a regular old 9V battery? That way we could figure up how many watts were going to it. I just looked and it doesn't say the amps on it.
Team CACO Team SHOK
Supporting Member
Old 01-18-2009, 04:13 AM
No, I'm not dead
0/11 sssss8128
I'd have to have one to hook to a speaker. I've got a Fluke 336 clamp ammeter I could get a true reading with. Offhand I'd venture to guess it's less than 1 amp sustained, most likely 1/2 amp.
Old 01-18-2009, 04:15 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
So say it was 1amp, then I was giving it a whopping 18W.
Lol.
Team CACO Team SHOK
Supporting Member
Old 01-18-2009, 04:16 AM
No, I'm not dead
0/11 sssss8128
Yeah, that's about it.
Old 01-18-2009, 05:17 AM
0/11 sssss1560
wait... V*V=Watts = not true?
Old 01-18-2009, 05:28 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Where did you hear that?
Team CACO Team SHOK
Supporting Member
Old 01-18-2009, 05:53 AM
0/11 sssss1560
this post?
or do you mean voltage squared?
Old 01-18-2009, 06:10 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
It's volts x amps / ohms = watts
Team CACO Team SHOK
Supporting Member
Batteries MazzaSEC Wanting to Buy (WTB) 3 01-24-2009 04:24 PM
Think your batteries sweet? SPL Guru General Car Audio Discussion & Questions 34 11-05-2008 03:00 PM
question about batteries waresgaragestereo General Car Audio Discussion & Questions 8 11-05-2008 11:00 AM
Understanding Car Batteries SPL Guru Tutorials & Quick References 1 10-28-2008 10:07 AM
Recycle your batteries! SPL Guru Off Topic Chat 14 10-08-2008 12:55 PM
