Big 3 questions for rear battery - Car Audio Classifieds!
Old 01-19-2009, 12:49 PM
0/11 sssss9745
Default Big 3 questions for rear battery
I have a 2000 Lincoln LS and the factory battery is located in the trunk. How would I go about doing a big 3 upgrade. Wouldn't having such a long power cable coming from the fron kinda cause more of a problem than help?
I've done the big 3 on cars with everything up front under the hood and can see how it would help but if I am already using 1/0 for a regular (all under the hood) then I have to take the 1/0 for the battery all the way to the trunk wouldn't it loose the effect?
Old 01-19-2009, 12:51 PM
98AckCL23's Avatar
0/11 sssss9929
not if factory wire is smaller than 1/0... If your factory wire is smaller, which it most likely will be, then upgrading to 1/0 would show you an improvement. while it most likely won't be as much of an increased effect as if your battery were 2-3 feet from the alternator, it'll still help...
Old 01-19-2009, 12:52 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Get 5/0 welding cable. Or go to your nearest telephone pole.
Team CACO Team SHOK
Supporting Member
Old 01-19-2009, 12:53 PM
brtnboarder3241's Avatar
0/11 sssss1595
I remember my friends gf having the batt in the back of her cobalt..imho ive never dealt with it but if its bigger than your stock then it will def improve the performance.. maybe not help since the battery is further away but will help
edit:beat me to it 98..hah
RON PAUL 2012
Old 01-19-2009, 12:56 PM
0/11 sssss9745
* Climbing pole now *
I sure hope this is the telephone line
Old 01-19-2009, 12:58 PM
98AckCL23's Avatar
0/11 sssss9929
the electric wire should work too, just don't touch the ground and the wire at the same time...
Old 01-19-2009, 01:02 PM
0/11 sssss9745
I'll go ahead and do it, can't hurt I guess.
Anyone every did it on a rear battery car?
Old 01-19-2009, 01:23 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
I think on ROE back in the day there were some people with Chargers or something that had the batt in the back, just ran a 1/0 run back there.
And telephone is ran underground, the lowest one is cable tv, an the top ones with the insulators are power.
Team CACO Team SHOK
Supporting Member
Old 01-19-2009, 01:26 PM
0/11 sssss3638
why not throw a batt under the hood? a lil custom work and your done
Old 01-19-2009, 01:34 PM
0/11 sssss9745
No room. That's why they moved the battery to the back. The v8 takes up most of the room.
Any questions you just couldn't get an answer to.. I can help. iamsonic New Member Orientation 47 10-14-2017 11:54 AM
Phone questions DLP customs Technology & Computer 9 01-06-2009 07:41 PM
Rear Deck rattle? mazda6i07 Off Topic Chat 5 11-21-2008 10:36 AM
Pioneer Questions flores210 General Car Audio Discussion & Questions 8 11-16-2008 11:56 PM
rear-loading folded horn box build SPY Off Topic Chat 22 10-08-2008 08:21 PM
