Help! Wiring 2 Sundown SAZ-3000s to 2 subs. - Car Audio Classifieds!
Old 01-20-2009, 07:05 AM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Help! Wiring 2 Sundown SAZ-3000s to 2 subs.
Subs are wired together at 2 ohms. I have 2 sundowns running, 1 amp for each. The subs are both seeing 2 ohms and putting out 1600 to each sub. Which output terminal do I put the speaker wire in. Left or right. It says for 1 sub its right, 2 its left, but the amps are not strapped. Help?!?!
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 01-20-2009, 07:48 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
This doesn't make sense.
If the subs are wired together to 2 ohm, then you have your amps strapped?
Or is each sub wired independantly? If they are independant then just use the right side for one sub. Now if you have just one open left and one open right (from the subs) then the amps must be strapped.
My Car, My Ears.
Old 01-20-2009, 07:59 AM
Team Sundown/MD Sales Rep
0/11 sssss1351
the 3000 has 2sets of outputs. Sounds like he wants to bridge the amps. If thats the case use the + of one side amp the the - of the other side.
-Jimmy
Team XS Power
/ Team Sundown / Team SHOK
MD, PA, DE Sundown Audio Sales Rep
SHOK Industries Dealer
Old 01-20-2009, 09:17 AM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Assuming they're not strapped, it doesn't matter which speaker outputs are used on the amp. They are monoblock amps so there's only one channel even though there's two outputs. Both outputs are wired parallel inside the amp.
Old 01-20-2009, 02:59 PM
0/11 sssss3784
Not Strapped! Each running 1 sub individually!
each running 2 ohm, 1600w, to an Earthquake DBXi-12d.
empty trunk
DC Power 270xp
.... so far
Old 01-20-2009, 03:03 PM
there is your answer
Old 01-20-2009, 03:07 PM
0/11 sssss3784
Awesome. Last thing. I am gettin a nice whine from the amps while its running. the lower the music and quieter the whine. I think its the amps because I turn the car off and the whine still goes until the automatic shut off kicks on and all the amps turn off. ideas?
empty trunk
DC Power 270xp
.... so far
Old 01-20-2009, 03:12 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
re-ground them, try a different location with the shortest runs possible with the bare metal being used as the mounting point.
My Car, My Ears.
Old 01-20-2009, 03:17 PM
0/11 sssss3784
take out the 2 runs of ground under the car?
empty trunk
DC Power 270xp
.... so far
Old 01-20-2009, 03:20 PM
0/11 sssss1351
are they ran up to your battery?
-Jimmy
Team XS Power
Sub Wiring ??? Blackout General Car Audio Discussion & Questions 18 01-30-2009 06:59 PM
Sub Wiring Help dkhage1 General Car Audio Discussion & Questions 4 01-19-2009 09:22 PM
TV With All Wiring Blackout Car Audio Trader (WTT) 6 12-24-2008 01:02 AM
Wiring RidnClean General Car Audio Discussion & Questions 16 11-03-2008 08:19 AM
Re: Wiring forceww Recycle Bin 0 08-14-2008 02:03 AM
