got a quick ? cuz ive never seen this - Car Audio Classifieds!
Old 01-21-2009, 06:21 AM
waresgaragestereo's Avatar
Active Member
0/11 ssssss787
Default got a quick ? cuz ive never seen this
i have a 89 Bronco II. I know how to do the big 3 quite nicely but ive never seen this b4. the alternatore has 2 bundles of wires that plug into the alt but no stud with a nut to put a ring terminal on so how do i do it?
Zach Ware
Making things loud, its what I do.
DO NOT ORDER FROM AUTOPARTSGIANT.COM
Old 01-21-2009, 06:22 AM
Biggy's Avatar
Loyal Member
0/11 sssss2240
pic?
If you hear any Clipping, it may be your Ears or the Coils hitting the End Stop
Sundown Audio Germany
Hey, what can I say? I love me some poonanner. Even if I have to hit them with a door and handcuff to the chair.
Old 01-21-2009, 06:24 AM
Active Member
0/11 ssssss787
will get one later on but theres no stud for a terminal like on a regular chevy or honda alt. just those 2 big plugs. theres no wire from the battery going to the alt what so ever.
Zach Ware
Old 01-21-2009, 03:02 PM
0/11 ssssss397
None? That seems quite strange. Hopefully pics will help you get an answer.
Old 01-21-2009, 03:05 PM
toyota thundra's Avatar
TEAM-ADDICTIVE-AUDIO JOSH
0/11 sssss1896
Where do the bundles go? Into a fuse panel?
** Team Addictive Audio **
** Team 813 Customs **
** Excessive Amperage HO Alts **
** Seismic Disturbances C.C. Central FL Chapter **
ill call la migra if she gets fake tits.
L00K Here.... IM BACK BEYOTCH!!!!!!
Ive been gone for a while and I seriously missed you guys... Glad to be back.
Old 01-21-2009, 03:08 PM
yep ford was gay with that I'm pretty sure my brothers is like that damn even my 73 has a stud for it
Old 01-21-2009, 05:54 PM
Active Member
0/11 ssssss787
here it can be seen where the bundles plug into the alt.
this is what the wire on my battery looks like. no wire for the alt tho
Zach Ware
Old 01-21-2009, 06:01 PM
Blackout's Avatar
0/11 sssss2427
This isnt going to be of much help because I cant think of the name for the part, but there is a splitter of some sort you can use. I did that with an older Ford car I was working (51) but it had a 305 in it.. Is yours a 351??
"I'm kicking you off my buddy list b*tch, I hope you & your computer catch a virus!"
Old 01-21-2009, 06:04 PM
0/11 ssss31255
I believe your positive wire needs to go to the selenoid input. Then plug in the harnesses and be done.
Were you looking to upgrade wiring? It's not an easy one to do it on. In that set up the factory harness uses the [alt] light in the dash not quite as the excitor but it will not charge if it's not hooked up.
This all assumes it's the right alternator for the bronco II.
Old 01-21-2009, 06:05 PM
Blackout's Avatar
0/11 sssss2427
x2
Could do that also, it would work
quick announcment basebalz13 Off Topic Chat 40 05-22-2010 03:31 AM
Amp noise. *Need help quick* Bushj311 General Car Audio Discussion & Questions 23 01-14-2009 11:18 PM
Quick question. rdaudioman1256 General Car Audio Discussion & Questions 3 11-16-2008 12:09 PM
Quick FYI- active vs passive SPL Guru Tutorials & Quick References 11 11-03-2008 08:40 AM
Quick how to- figuring box volume SPL Guru Tutorials & Quick References 0 09-30-2008 11:24 PM
