Fusing Q - Car Audio Classifieds!
Old 01-26-2009, 10:23 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
Default Fusing Q
So lets say i have a vehicle.. in this vehicle there are 2 runs of + and 2 runs of - from the front of the truck to the rear in the rear of the truck there are 2 batteries. My question is should you fuse the positive lines in the front and the back or just in the front?
Old 01-26-2009, 10:24 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
i would just do back after the second battery.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 01-26-2009, 10:30 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
i dont exactly get what you mean.. but this is an illustration of what i mean
blue bars represent fuses
for the record i know i dont have to do a run of wire to each battery
Old 01-26-2009, 10:32 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
mine is fused in the front.
92 Ranger Walkthrough
(Under Construction)
Old 01-26-2009, 10:35 PM
98AckCL23's Avatar
0/11 sssss9929
mine is fused on the positive terminal, and I have a breaker about 5 inches before the rear battery. the breaker is probably overkill, but i've used it when my starter took a shit on me...
Old 01-26-2009, 10:48 PM
no that would be bad
fuse in the front and back
fuse in front is to protect wire
fuse in back is so if there is a short electricity doesn't travel backwards and start a fire
Old 01-26-2009, 10:51 PM
0/11 sssss3638
i just have a fuse in the front, but you SHOULD do it at both ends
Old 01-26-2009, 10:54 PM
DLP customs
Guest
0/0 sssssssss
I fuse in the front. I dont see a reason to in the back because the voltage already crossed the first fuse to get to it. Therefore if its over the amp load the fuse takes it will blow and wont get to the second one.
Old 01-26-2009, 10:57 PM
thats not what it's for though
lets say (this is extreme) your power wire gets cut in half after the first fuse and the vibration caused by driving causes it to slid into some metal and since there is no fuse in between the back battery the electricity will try to get to the ground through the metal in the car which will spark which in turn could catch the insulation and carpet on fire
Old 01-26-2009, 11:01 PM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
...and the 2 big batteries conveniently located inside the car might xplod
