Need quick help - Car Audio Classifieds!
Old 10-10-2010, 09:53 PM
0/11 ssssss249
Default Need quick help
ok i need an answer by tomorrow this dude says to me "My dad and i hooked up my system last night. iran the amp to a seperate bat along with my cap. and for some reason my highs shut off whenever i turn my headlights &interior lights on then my drivers side door speakers are cutting out its a 97 pontiac 2 dr" need ideas or if you know exactly how to fix it please tell me thanks
2 Memphis 15-C312D4's 1 Memphis 15-CM12D2 and 2 Memphis16-MR1.1200 with a set of Memphis 15-PRS5V2 and a set of Memphis 15-PR692V2's being pushed with a Clarion 90x4
Old 10-10-2010, 09:56 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
The overall electrical is not putting up with his stuff bcz he did something wrong. Ditch cap, make sure the batts are wired parralell. Big 3 is very important, and it isn't always good to have a lead acid batt with an agm batt. I would put the second batt as the primary only under the hood batt...but what's his total wattage?
Old 10-10-2010, 09:59 PM
0/11 ssss31255
your wiring is messed up.
assuming you are using an amplifier, the highs shutting off indicates your turn on lead is connected to the illumination wire of the headunit.
The drivers door speaker cutting out indicates either it's dying.. or you have one of it's leads connected to the wrong wire also.
Old 10-10-2010, 10:23 PM
FAUEE's Avatar
0/11 sssss1081
Tear it out, start over, do it right.
As the others have mentioned, something in the wiring is wrong, likely due to the illumination wire. That said, I imagine it's not the only thing wrong, and the bes course of action is to rip it all out, start over, and do it right while charging accordingly.
Old 10-10-2010, 10:25 PM
0/11 ssssss249
ok thanks guys im still learning but i had around the same idea both of you said just dont want to mess it up really appreciate it guys
Need Quick Help. KickerCobalt Off Topic Chat 4 03-13-2010 01:01 PM
Need some quick help. sdelthon General Car Audio Discussion & Questions 7 10-30-2009 12:48 PM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
quick box help RidnClean Enclosure Discussion & Design Construction Help 15 06-15-2009 01:27 AM
HELP! qUICK! obrien202 General Car Audio Discussion & Questions 10 06-14-2009 09:34 PM
