changing idle voltage on alt - Car Audio Classifieds!
Old 10-11-2010, 09:47 AM
9515ROB's Avatar
0/11 sssss2057
Default changing idle voltage on alt
i have a ford 3g internal regulated 250amp alt. I was wondering if i took it to a alternator shop if they could get inside it and change my idle voltage.
Or is it was how the wound the coil so it isnt possible to be changed
Being loud is waste of money
880prs/Front-Hybrid Audio Technology Legatia L8 L3 L1v2 3-way/Sub- 3 blown MB Quart RLP-304 shallow mount 12s/Sub Amp- Visonik v2908/4ch- DD C4a
Still got a lot of stuff left to get
Old 10-11-2010, 09:55 AM
0/11 ssss31255
Changing voltage is probably not what you are looking to do.
Changing the voltage changes the amperage. {Voltage up = amperage down} {Voltage down = amperage up}
You can change idle output by changing the pulley diameter. This leaves your alternator as it is designed but allows it to give maximum output at a lower RPM {such as idle}
How To Increase Idle RPM? brandonb1029 General Automotive Chat 13 10-21-2010 10:54 PM
what much does the mechman 260amp have at idle murkr General Car Audio Discussion & Questions 2 09-27-2010 02:33 PM
up my idle? Nd_6037 General Automotive Chat 19 09-18-2010 08:19 PM
I need a alt that puts out on idle robertawdgsx General Car Audio Discussion & Questions 20 02-12-2010 12:47 AM
Need more idle output on a budget??? MECHMAN General Car Audio Discussion & Questions 15 06-24-2009 06:47 PM
