how to... - Car Audio Classifieds!
Old 10-11-2010, 01:01 PM
0/11 ssssss600
Default how to...
i got 2 Massive P1000.1 amps they do 1000 @ 1 ohm each. I am tryin to push 2 Massive CW 10s. I was messin around a few days ago with the amps and ran the rcas to one amp and used the other rca outputs and ran another set of rca cables to the other amp. Then i ran a positive from one amp and a negative from another amp and the subs both worked. Is this a proper way to run subs or are my amps in danger of messing up or am i just wrong period.
The reason i did this is because i would rather run to much power rather then runnin too less of power to the subs. Amps only do 500 rms @ 2 ohms.
Old 10-11-2010, 02:04 PM
0/11 sssssss28
I'd never recommend using two different amps to power 2 subs without stacking/linking them to equalize the voltage/output between them(especially if they're going to into a box with a shared chamber). I'd do a little more research before you mess up your equipment. I don't know whether those amps are stackable by themselves. If not, you'll want to look into a Maxxlink or similar in order to do it right. Like I said, do the research because I'm not sure if Maxxlinks are only usable with Maxxonics products or not. Probably not the most help for you and I'm sure others will chime in, but the info is out there...you just need to look.
