Questions about powering subs - Car Audio Classifieds!
Old 10-12-2010, 05:32 PM
0/11 sssssss15
Default Questions about powering subs
I have a pair of Hertz HX250D 10" Subs with dual 4 ohm voice coils. Power handling is 450 RMS and 900 Peak.
I plan on putting them in a pair of around 0.4 cubic foot sealed enclosures in my Maxima. I have a Sony Mobile ES XM-7557 5 channel amplifier that is stable down to 0.5 ohm and will do 360 watts RMS into 1 ohm and around 500 peak watts. Can I run 1 or both of them if I play my system at reasonable volumes? Will the subs reach beyond my trunk with that setup?
I am thinking about not using the sub channel and getting a mono amp in the 900-1000 watts RMS range.
I fear that I am going to have to get a high output alternator though. Especially with a 2nd amp.
Doug
Old 10-13-2010, 11:37 AM
0/11 sssssss15
Does anyone have any feedback on this?
Also, does changing the sealed box size to a larger size help with lower wattage amplification?
Doug
Old 10-13-2010, 11:49 AM
Boomsday's Avatar
0/11 sssss1929
Feedback Score: 25 reviews
Your gonna underpower ur subs if you run one or both...I would just purchase another amp that did [email protected] 1ohm, a decent can be had pretty cheap..
Also running 1k you will not need to worry about a HO Alt..
Old 10-13-2010, 11:55 AM
0/11 sssssss15
The XM-7557 is a 900 watt amp (4x100 +1x500 peak) and it states that it takes 81 amps peak, 41 amps at RMS. With the combined amps, would I still be okay? I am not into very loud volumes.
Thanks,
Doug
Old 10-13-2010, 12:07 PM
Boomsday's Avatar
0/11 sssss1929
You will be fine, peak amps are pointless just a marketing thing, and unless you drive around with everything up all day, you will not draw the 41amps either..
Old 10-13-2010, 12:11 PM
4/11 ssss31258
should sound pretty good.
yes, if you amplifier can handle the 1ohm load you can run both subs.
also, the smallest power wire you should run would be 4 gauge. {btw / fyi}
Old 10-13-2010, 12:14 PM
0/11 sssssss15
Excellent, thank you for the replies. I'm going to get a good quality Diehard battery and will give it a go.
Doug
Old 10-13-2010, 12:28 PM
stills's Avatar
Mid-fi maven
0/11 ssssss374
how 'bout some pics of the ES?
team lullaby league
Old 10-13-2010, 12:54 PM
0/11 sssssss15
Sure, I'll take some pics and include them as soon as I can.
Doug
Old 10-13-2010, 12:58 PM
0/11 sssssss15
I am looking at a Nakamichi PA-1500 mono amp. They have been marked down a lot recently ($279 now). I think that it will do nicely!
Doug
Powering the 3500D Bigbodylexus (Sundown Audio) 25 01-11-2011 10:30 AM
Powering two gp3k Mr.Green General Car Audio Discussion & Questions 6 08-13-2010 01:51 PM
New subs ,New setup, New questions!!! larry General Car Audio Discussion & Questions 10 04-01-2010 08:58 PM
powering a lvl 4 xl ? JusRsounds (DC) 3 03-10-2010 09:33 PM
Powering soundstream xxx6500 Dhern409 General Car Audio Discussion & Questions 12 12-13-2009 07:31 AM
