Doubling power-how much gain have you actually seen? - Car Audio Classifieds!
Old 10-12-2010, 05:36 PM
Dbmonster's Avatar
0/11 sssss1217
Default Doubling power-how much gain have you actually seen?
We all know the 3 db rule of thumb, doubling your cone area or doubling your power should result in a gain of 3 db. But of course this is theoretical. So in real life how much gain have you achieved by doubling your power on the same woofer/box setup?
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 10-12-2010, 05:46 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
From 1 amp at .25 too 2 at .5 i gained 2db
From 1 amp at 1ohm too 2 amps at .5 i gained right ar 3.8db
Youtube VIDz :
Old 10-12-2010, 05:49 PM
poundstone's Avatar
0/11 sssss1635
i gain 2.5 db on average dropping from 1 ohm t .25 and we clamped 4000w at .25 and 2400 at 1 ohm so i think there is but im sure there is a limit to that!!!!
2011 and 2012 usaci streetbeat 2 world champ
2012 2nd iasca advnw1 and lightweight bassboxing
2013 usaci mod 1001-2k world champ
2013 second meca mod 5
2014 mwspl adv 2 world champ
2014 meca mod 4 world champ
usaci streetbeat 2 world record holder b and k
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
Old 10-12-2010, 05:59 PM
ascitiesburn69's Avatar
0/11 sssss1645
I gained 6+db from doubling cone area AND power.
Team S.P.E.A.D.
Trunks FTW
Old 10-12-2010, 06:05 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Thermal compression is what limits it. It can be as less as 1db if you have ALOT of wattage on it.
Old 10-12-2010, 06:08 PM
scott s's Avatar
Loyal Member
0/11 sssss1311
from 6200 to 10k i saw 1.3 that was in a street build
154.9 to 156.2
Team dc audio
sbn 23 09 stock 1 northamerican champ
sbn 23 stock 2 champ
meca 09 s4 champ
nspl suv hardcore wr holder 154.1
Old 10-12-2010, 06:15 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
1.9 from 1 ohm to .25.
1.7 by doubling cone area with a pair of 10's. Tuning changed though, so there was more in play there.
I gained 2.6 going from an RD2200 @ .25 to a SS DTR @.25. on the same setup. That's a HUGE gain just from swapping [email protected] (rated) amps.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 10-12-2010, 11:01 PM
Novicaine's Avatar
0/11 sssss6135
Not using as much wattage should literally help you out, but this is compared to high wattage. Just because a sub like DD, aq, etc takes ALOT of twattage dosnt mean that running it past there ratings without blowing them up will be free. People say things are overated, but honestly for all we know, aq and similar popular brands could overate due to the subs even producing a aittle of thermal compression at there own ratings. Thermal compression causes resistance.
So there tests should be done to findout if say, 6000w is very close enough to 3k due to better efficency. Like impedance rise. For comp, you want it to match the amplifiers lowest possible imp, so in this case why not be concerned with usiong less wattage...
Setting gain SQLbeliever General Car Audio Discussion & Questions 2 06-24-2010 07:02 PM
how to gain dbeez? fyerbyrd22 General Car Audio Discussion & Questions 12 06-23-2010 11:19 PM
Power/SPL gain from 1 ohm to .5, SD5k britdevine General Car Audio Discussion & Questions 1 05-22-2010 08:47 PM
Amp Gain Setting the Right Way whitedragon551 General Car Audio Discussion & Questions 19 03-30-2010 01:20 PM
How high is your gain set? hornedfrog1985 General Car Audio Discussion & Questions 7 09-05-2009 03:42 AM
