Big Big question, need help... - Car Audio Classifieds!
Old 10-12-2010, 06:26 PM
masterbarber's Avatar
0/11 ssssss114
Question Big Big question, need help...pic on pg2
Ok here's the deal; I have my wagon wich im putting a new system on, my factory alternator with the Big 3 upgrade was hiting 14.1 volts. But with the lights on and the system bumping the lights go low. So i decide to upgrade and bought a 165amp high power alternator and 2 extra bateries.
I just installed the bateries with 0 gauge and the new alternator, and when i crank the car on its hiting only 12.0 volts. Why? What im doing wrong? I dont get it . I can change the alternator if that its the problem cause it has warranty.
Can anyone give me an advise on this issue? Thanks in advance
Old 10-12-2010, 06:37 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
12v when it's running? At idle? What about when you are driving or revving the motor? Where do you have your voltmeter hooked up? How are the batteries connected?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 10-12-2010, 06:41 PM
MisterGrubbs's Avatar
0/11 sssss2358
Where are you reading voltage? From the same place
First, test the alternator. See what kind of voltage your alternator is charging at.
Second, make sure all batteries are good and charge them before you sit them in there, just to see if that helps.
Theres no reason you should drop voltage when upgrading your alternator and adding two additional batteries with the same power.
Old 10-12-2010, 06:42 PM
0/11 ssssss114
Even if i hit the gas to rev it still on 12v, the voltmeter i have hook up from the front battery to the back and ground it. The bateries on the back are hook the normal way.
Old 10-12-2010, 06:44 PM
0/11 ssssss114
The bateries are good on charge and all the same.
Old 10-12-2010, 06:45 PM
0/11 ssssss589
have you calibrated the voltage meter?
Old 10-12-2010, 06:48 PM
B.Haley's Avatar
0/11 ssssss614
alt not charging at all? car off voltage should be higher
upzaudio's Avatar
1upz all on the meter
0/11 ssssss322
ok im just going to ask not to be an ass because ive done this 1 time...
did you connect your alt back to everything right?
because i thought i did all right, and then after yelling a some guys noticed it lol
Old 10-12-2010, 06:49 PM
0/11 ssssss114
Ok, i have a Stinger Digital LED Voltage Monitor
Old 10-12-2010, 06:51 PM
0/11 ssssss114
I know, i dont get it
Every single plug and wire its good
box question (NOT A DESIGN QUESTION) highpsicobra General Car Audio Discussion & Questions 0 07-15-2010 02:10 AM
ELT 12 question thumper21 General Car Audio Discussion & Questions 4 06-02-2010 10:18 AM
16V question Duaber General Car Audio Discussion & Questions 24 03-03-2010 07:40 PM
I have a question? WrenchGuy Announcements - Suggestions - Feedback - Support 4 10-27-2009 08:49 PM
UPS question RidnClean General Car Audio Discussion & Questions 20 07-03-2009 09:51 AM
