Shifted Pole Backplate, still usable? - Car Audio Classifieds!
Old 10-13-2010, 04:39 AM
Biggy's Avatar
Loyal Member
0/11 sssss2240
Default Shifted Pole Backplate, still usable?
Ok, i got this SX Motor sitting here since some time.
I wanted to Recone it from a 12 into a 10" but used too long screws and the topplate came off.
today i glued to to plate back on and realised the blackplate/pole is shifted slightly to one side (about 1.5-2mm)
now i aligned the topplate to the pole so it is also slightly shifted.
the coil fits in nicely, but will it have any diffrence in work? like the magnet field is higher on one side than the other or something like that.
If you hear any Clipping, it may be your Ears or the Coils hitting the End Stop
Sundown Audio Germany
Hey, what can I say? I love me some poonanner. Even if I have to hit them with a door and handcuff to the chair.
Old 10-13-2010, 04:41 AM
0/11 sssss3986
if the coil does not rub then you should be fine as long as the basket and spiders and everything are lined up correctly when you recone it.
Old 10-13-2010, 04:54 AM
0/11 sssss2264
Feedback Score: 33 reviews
ot, but what kinf of glue is used to re attach the top plate?
pretty sure the lms coil just aids in some woogey boogy shitt called SQ
Whats prototype about an off the shelf design in an off the shelf casing?
Old 10-13-2010, 11:17 AM
Biggy's Avatar
Loyal Member
0/11 sssss2240
i've used some 2k "superglue" for metal
it's pretty strong, so i don't worry about it comin loose again
WTB shifted motor F3M4 Wanting to Buy (WTB) 12 10-08-2010 11:16 AM
Pair of old school JL 12W6 baskets/motors, shifted poles. TREETOP Broken & Non-working equipment 1 10-01-2010 09:06 PM
Shifted pole piece question sqcrewcab (Fix My Speaker) 10 11-10-2009 02:19 AM
broken but usable psp e-lo1 Broken & Non-working equipment 3 08-08-2009 10:25 AM
looking for motors with shifted/cracked/junk magnets to rebuild. orangelss Wanting to Buy (WTB) 0 06-09-2009 09:31 PM
