waaaaaiit a minute... - Car Audio Classifieds!
Old 10-13-2010, 09:36 PM
Captain Tying Knots
0/11 sssss1220
Default waaaaaiit a minute...
if an amp has 2 positive and 2 negative speaker wire terminals and you hooked up the positive and negative of each coil of a dvc woofer to each terminal ( a 2 ohm dvc for example) what ohm load would the amp be seeing?
Old 10-13-2010, 09:38 PM
Mattd0344's Avatar
0/11 ssssss443
Depends on the impendance of the sub..if it is a mono amp, the pos and neg terminals should be internally bridged. Wire everything in parallel, it'll see a 1ohm load
Head Unit: Kenwood Excelon KDC-X794
Subwoofer: 15" Fi SSD
Sub Amp: MB Quart DSC-1500.1D
Wiring: Shok 0 Gauge CCA
REFS
Sold to: krazykarl, power-fanatic07, Ellsworthz, jhughes, bornintothis, RetroAudioInc, 813thumper, jjbeenken, Inferno333, tuck05, kaaialii, 09Alti, kodak314/sostl, Worstenemy453, hrtbrk1, jesuspunk25 and jamesw
Bought from: sundownz, ls2poweredgoat, and blue200sx
Traded with: dB-r, skateguy92, and 5.3bowtie
Team Shok
Old 10-13-2010, 09:41 PM
Captain Tying Knots
0/11 sssss1220
so youre saying if i just connected the 2 positive terminals on the sub to the 2 on the amp and the same for negative for a d2 sub it would see a 1 ohm load...
Old 10-13-2010, 09:45 PM
813thumper's Avatar
0/11 sssss1116
I LIKE BUILDING ENCLOSURES FOR CUSTOMERS
Old 10-13-2010, 09:46 PM
Captain Tying Knots
0/11 sssss1220
Originally Posted by 813thumper View Post
this wasnt a question about how to wire it, i was just wondering what the final load would be.
Old 10-13-2010, 09:48 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
If im reading this right: 1 ohm would be your final starting load
Louder. Lower.
Team Tupperware
Old 10-13-2010, 09:49 PM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
and he's answering it. As stated before if the amp is a mono amp then it will bridge the positives and negatives giving you a 1 ohm load.
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Captain Tying Knots
0/11 sssss1220
mind=blown i didnt know it was that easy
If you have a minute, take a look at this excursion! STR8BLaZiN Car Audio Videos 8 08-01-2010 04:19 PM
Last minute build for "Scrapin" TaylorFade Build Logs 5 06-25-2010 01:00 PM
BRUTAL 15 minute install = INTENSE Flex ! TylerTron Car Audio Videos 9 05-20-2010 11:02 PM
lulz i had a minute ago michael707 Off Topic Chat 14 01-06-2010 10:51 AM
Last minute fight Patrick Simmons Sports and Fitness 48 08-18-2009 11:13 AM
