us amps xterminator xt2000d turns on, off, on , off and so on. - Car Audio Classifieds!
Old 10-14-2010, 09:30 PM
0/11 sssss1053
Default us amps xterminator xt2000d turns on, off, on , off and so on.
i have a us amps xt2000d xterminator series.. the v1.
i had it running at 1 ohm and it was pushing a dual 2 ohm image dynamics idmax 12 wired up to a 1 ohm load in a sub zero ported box.
gain set a hair below half way, bass boost a hair below half also, lpf was all the way down.
amp subwoofer level on headunit was on 5 out of 15 and the bass was on negative 2..
it was bumpin fine for a week then one day i thru on "late nite tip" and the amp was fine.. not hot or anything... when the song finished so did my amp...
now all it does is turn on with the green light then go right to red, then tries to turn on again with the green light and then goes back to red.. and keeps doing this untill i disconnect all power..
i tried the amp with no rca's or speaker wires connected.. same issue..
i openes up the amp and cant spot anything visibly wrong..
even took it out car and bench tested it.. same issue..
what could it be in your opinion's..
thanks...
U.S. Amps Xterminator XT4000D Parker G Mono Amplifiers 14 07-06-2010 07:55 PM
What do you think about the US Amps Xterminator XT2000D? Novicaine Sound Quality Area 11 07-05-2010 01:53 PM
SHould i trade for a t3 ts10d4, or an xterminator xt2000D? which would u go for? Novicaine General Car Audio Discussion & Questions 13 06-26-2010 06:07 PM
US Amps XT2000D MHD2000 Mono Amplifiers 1 06-06-2010 08:47 AM
