something to eat corrosion off motors - Car Audio Classifieds!
Old 10-15-2010, 02:49 PM
0/11 sssss3164
Default something to eat corrosion off motors
what do you guys use to eat the corrosion off motors with, or do oyu just wire wheel the motor? ive only had my axis woofers for like 3 months and im guessing that since i lived on the coast they got this way but anyways heres what im talking about. i didnt want to scratch the motor but i do want this crap off is there anything particular chemically that i can pick up for this?
Old 10-15-2010, 02:52 PM
TNJ
0/11 sssss7882
i woudl be worried about the pole piece rusting inside too against the vc.
Old 10-15-2010, 02:54 PM
0/11 ssssss195
CLR? I'm not sure >.<
Old 10-15-2010, 02:55 PM
0/11 sssss3164
theres no rust even close to the vc bro. the pole vent has no rust in it. its only the bottom edges of the motor. but thanks for the concern
Old 10-15-2010, 02:57 PM
0/11 sssss3164
hmm. idk, i have some rust removing stuff. i think its called marine jelly. that could eat the rust i guess then clr could eat the corrosion maybe. idk i was just wondering what others used or if they even used anything. my truck let in alot of moisture but thats the only spot on the woofer where i saw rust. its very minor surface rust
Old 10-15-2010, 02:58 PM
TNJ
0/11 sssss7882
i was just thinkin since its got the vent in the pole moisture would get pulled into there while playing. just what first came to mind. i would try some clr like recommended. put it on a rag and scrub.
Old 10-15-2010, 02:59 PM
Man Behind the Curtain
0/11 sssss1699
Yup it works, it works better if you can let it sit in the clr.
Old 10-15-2010, 03:01 PM
Slam's Avatar
I slam
0/11 sssss3772
SOS pad
Old 10-15-2010, 03:06 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Double ott steel wool
Old 10-15-2010, 03:09 PM
0/11 sssss3164
that steel wool would probly scratch up the motor or? i know the motor has circular grooves like a tree kind of and i didnt wanna mess that up. ill try some clr and maybe a lil bit of something to rub it with
rf hx2 motors /coil and audiobahn aw1500 motors 1outof7 Wanting to Buy (WTB) 2 01-25-2011 07:17 PM
WTB: 9500g motors or similar motors Zooook Wanting to Buy (WTB) 24 10-21-2010 09:53 AM
Battle against corrosion. Josh Wahlie General Car Audio Discussion & Questions 7 09-16-2010 05:41 PM
hey dbr i have a quick question about corrosion on an amp ellocojorge (db-r) 6 08-11-2010 03:53 PM
Aluminum Corrosion SundownAudioNY General Automotive Chat 10 01-18-2010 12:09 PM
