Should I use some foam to seal my back window or would it cause it to break - Car Audio Classifieds!
Old 10-16-2010, 08:34 PM
46panel's Avatar
0/11 sssss1662
Default Should I use some foam to seal my back window or would it cause it to break
So if you've seen my video of my explorer flexin the back window is moving so much you can put your finger in it. I've heard that you can buy some foam from like home depot that has adhesive on one side to put around the window to help keep some of the pressure in. One of my buddies did it and said it made a big difference, just seeing if it would be worth it, because I don't want to make it so tight that the pressure breaks the window.
http://www.youtube.com/watch?v=GoZrJ6Q69Xk
2007 Chevy Impala: JVC KW-V10, Sundown Nightshade 15", Planet Audio Big Bang 2400, Alpine MRP F450, JBL P660C components.
Old 10-16-2010, 08:57 PM
0/11 ssssss651
Thats insane that damn thing aint broke?
Sundown SA-12s
Sundown SAZ_1500
Sundown x2 SAX-100.4D
But not team sundown
refs:corona_jeff, andrewtexas123, fasfocus00, Nickatina, 97maxima, Dirtydood, Markak134, Curse,Cl1ckClack,cdawgstalon,JarvisB,Boomsday,Indy bangin,surreal,korn4life
Old 10-16-2010, 09:06 PM
0/11 sssss1411
the hatch glass on my 84 corvette used to do the same thing.
I was also amazed it did not end up breaking
Old 10-16-2010, 09:07 PM
0/11 ssss31256
I'd say make it so the glass doesn't open.
Just run a bead of silicone around the rubber seal of the window and close the window. let it dry and your window will be secured. This would allow it to be easily undone if you ever wanted it to be usable again.
Old 10-16-2010, 09:12 PM
46panel's Avatar
0/11 sssss1662
Not yet and I hope it dont lol
Yea pretty crazy
Just worried cuz if its siliconed then its not going to move at all like you said, and then the amount of pressure on that back window is going to be even worse, that's why I thought about doing the foam, cuz was told it helps seal but doesn't make it SO tight it doesn't flex at all.
Old 10-16-2010, 09:19 PM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
I thought the same about him..
http://www.youtube.com/watch?v=7hcGEotbHdU
Old 10-16-2010, 09:29 PM
46panel's Avatar
0/11 sssss1662
Nice, but yea need to know if I should do something.
Old 10-16-2010, 09:32 PM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
I dont think you will break your glass the way it is, Ive seen some pretty wicked flex on the back hatches on Suv's and they are Daily Ground Pounders. Just my 2 Cents
Old 10-16-2010, 09:33 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
i feel like it would hurt to try. worse comes to worse, and it does break (which i think it wont) you can jsut snag one at the junkyard and you've learned somthin. to me and my thought process anyway, id think the window flexing an inch, puts more stress on it than if it was sealed and had pressure on it.
-Youtube Channel
Old 10-16-2010, 09:36 PM
46panel's Avatar
0/11 sssss1662
Hmm yea, but then another guy with an explorer told me that he had someone putting pressure on his back window when testing and it caused the window mounts to break. Might just try it and see.
4 18's flexing the back window a little bit 46panel Car Audio Videos 39 10-19-2010 03:48 PM
Is a sub gasket vital to seal the sub or can i get away without? Novicaine General Car Audio Discussion & Questions 14 07-01-2010 06:50 PM
db Drive, Cadence, and Peel and Seal Review and Build Bobby32 Build Logs 34 06-09-2010 09:06 PM
Best way to seal the back of componants/coax's in the door +rant MaTT6387 General Car Audio Discussion & Questions 0 06-03-2010 10:52 PM
So, I told the dude not to paint a seal on the bottom... F3M4 Off Topic Chat 2 04-24-2010 11:09 PM
