soft fluttering sound from sub - Car Audio Classifieds!
Old 10-16-2010, 10:27 PM
apbt55's Avatar
0/11 sssssss76
Default soft fluttering sound from sub
I have 2 lanzar opti1535ds, got them used.
one had a little bit of mechanical noise when I got it, then it kind of sound like the dust cap might be coming loose, flapping with high frequency bass. when I pushed on one side of the dustcap it went away, if I pushed on the other it got louder. It has gotten more frequent and pronounced. I checked and can't find any loose spots in the dustcap, even put a little epoxy where it seemed it was coming from.
now basically seems like the sub is making light fart noise with most high frequency bass. I have the tiem to pull things out next weekend to see what it is, but was looking for thoughts. Trying to figure out if I really need a recone or not.
Aside from this noise the sub hits hard and low. the coils read correctly.
any ideas of what to look for first.
thanks for any advice
2004 nissan altima, 3.5L
275 amp DC power HO Alt, KHC1400 under hood. C&D UPS12-475-FR in back.
JVC Arsenal KD AHD59
AQ2200d (back up Soundstream PCA1500D)
MB Quart DSC4125
Crunch P1800.4
RF T1692, RF T1652-S in front, RF T1652 in rear door.
2 AQ SDC2.5-12 in ported box.
Old 10-17-2010, 02:47 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
sound like coil rub. doubt your dust cap is loose, and that would explain why when you press on one side it stops and the other makes it louder. usually sounds like scratching sound
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 10-17-2010, 02:57 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
there is an inner dust cap on that woofer i bet thats loose
or you got some crud int he gap and it is magnetic (that's why its still there) so its not gonna come out on its own
Old 10-17-2010, 03:03 PM
TNJ
0/11 sssss7882
sounds like the subwoofer has aids.
Old 10-17-2010, 03:58 PM
apbt55's Avatar
0/11 sssssss76
thank you, I will check the coils too, I was planning on taking the cap off and will also clean the motor and check that out.
it doesn't get louder as the subs play louder stays about the same, and is generally worse with rock songs.
if it is coil rub would a recone take care of that or do I have to worry about something possibly having shifted in the motor.
Damn STDs better double bag it next time, but guess that's what I get for taking sloppy seconds.
MB Quart DSC4125
Crunch P1800.4
Old 10-22-2010, 10:40 AM
Veteran Member
0/11 sssss3830
they dont have recones for that sub and the coil is an odd size i already checked with PSI you would need custom made coils possible but expensive
Old 10-22-2010, 10:53 AM
More spl's Avatar
0/11 sssss2638
Feedback Score: 29 reviews
Default If it is coil rub you would hear it when...
you push down on the speaker. If theres something in the speaker when you take it out the box shake it you would hear rattle check the terminals if the not direct lead some times they break like on kicker l5s and l7s and they rattle.If it has aids keep it away from the other speaker it may get infected when the trunk is closed.
Old 10-22-2010, 10:56 AM
apbt55's Avatar
0/11 sssssss76
Thanks, yeah they gave me the run around trying to get recone parts.
So I better hope it isn't the coil rubbing, seems a waste for the motor on it. Do you happen to know the
top plate inner diameter
the pole piece outer diameter
the top plate height
there is a guy on ca.com that works for a parts manufacturer, said he might be able to direct me to where to get parts, he is the wholesaler. if i get the info I will let you know
MB Quart DSC4125
Crunch P1800.4
Old 10-22-2010, 11:11 AM
Veteran Member
0/11 sssss3830
Here are specs
Pole o.d. 2.975 "
Top plate I.d. 3.150"
Coil o.d. 3.1"
Coil I.d. 3"
Winding length 2"
Total former length 5.25"
9.75 od spiders
if you get coils ill buy 1 or2
Some more soft top demo's Boyd Heaton (DC) 21 08-12-2010 09:10 PM
Soft Parts marcmdm2005 (Fix My Speaker) 7 06-09-2010 10:46 AM
12KD In the soft top Boyd Heaton Team SounDigital 2 05-30-2010 02:32 PM
F/s- Re mt -18 Psi soft parts 97maxima 18" Subwoofers 3 05-14-2010 11:18 AM
Is there any way to tell what soft parts on a sub? westman995 General Car Audio Discussion & Questions 6 07-31-2009 11:55 AM
