Speakers cut out, need help ASAP! - Car Audio Classifieds!
Old 10-17-2010, 02:13 PM
0/11 ssssss360
Feedback Score: -1 reviews
Question Speakers cut out, need help ASAP!
My MB Quart Premium PVI 216 component speakers the mids (6.5") look like they have some rust on them, and they cut in and out of play.
What is wrong with them? Did water get in my doors? This never happend with other speakers I've owned?
I just want to fix them somehow, there only 2 months old, and sounded awesome!
Any ideas?
EDIT: They aren't blown, they were ran off a clean 50 watts rms, crossed at like 120 hz. They push down very easy and never have been smoked or anything.
Old 10-17-2010, 02:14 PM
0/11 sssss5305
what's powering them, HU or amp?
connections might be rusty/corroded and losing connection.
Old 10-17-2010, 03:44 PM
0/11 ssssss360
Amp....I have some kenwoods replacing them temporarily, and they work fine (same amp and wiring)
The connections are rusty/corroded. Can I sand them down to make them work again
Old 10-17-2010, 03:54 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
You can sand to remove rust but should look into protecting the raw metal to prevent it coming back. liquid electrical tape works and can be found @ home depot.
If they are blown this ^^^ wont help
Old 10-17-2010, 03:56 PM
Partially Unwound
0/11 sssss2697
Try using foam baffles or some other shielding to protect the rest of the speaker from drips in addition to the connections
Old 10-17-2010, 07:54 PM
0/11 ssssss360
would sanding it fix it though? i would think so but idk
Old 10-17-2010, 07:58 PM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
Depends how bad rusty it is but yeah, Sanding will work. But you should look into protecting them from weather though.
Old 10-17-2010, 09:22 PM
0/11 ssssss360
How would I go about that?
Old 10-17-2010, 09:41 PM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
Where are your speakers located?
Old 10-17-2010, 09:45 PM
0/11 ssssss360
In the front doors.....
wtb: 4" speakers ASAP snoopysnooper Wanting to Buy (WTB) 6 08-11-2010 03:16 PM
Wtb asap Austin175 Wanting to Buy (WTB) 2 08-05-2010 05:41 PM
WTB Fi BTL!!!!! ASAP IWantBTLs Wanting to Buy (WTB) 3 02-15-2010 02:36 PM
need help asap!! newarkbeast973 General Car Audio Discussion & Questions 90 05-17-2009 12:21 PM
