D1200 + Which I-Bar? - Car Audio Classifieds!
Old 10-18-2010, 03:34 PM
AllenH427's Avatar
0/11 ssssss841
Default D1200 + Which I-Bar?
I need a front AGM battery to compliment my two Deka 9a31s going in the back. I'm new to electrical upgrades so bear with me here. I want something that will start up my car in the winter no problem. I was originally going to go with the D925 but I was concerned about how easy it'll be to start my car. But since my up front battery will be hooked up with my Dekas, shouldn't starting my car take power from all 3 of my batteries? If that's the case can't I go with something smaller like the D925?
And for either the D925 or D1200, which IBar should I get that will be able to fit these?
Positive Battery Terminal
I'm looking around by I'm not seeing the posts that will fit into the Knu battery terminal...
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
Old 10-18-2010, 04:04 PM
0/11 sssss1016
What vehicle is it going in? Do you need side posts or just 2 pair of top posts? If you are just looking for posts to put on the battery you can just get the 580 short brass posts or 586 tall brass posts.
'1.888.497.7693 x1211
Old 10-19-2010, 05:16 AM
AllenH427's Avatar
0/11 ssssss841
02 Camry. And I want a post for my Knu Battery terminal, and then an extra screw (wingnut) post for doing stuff like my big 3.
Old 10-20-2010, 09:50 AM
0/11 sssss1016
Not sure what the Knu Battery Terminal uses, but the 580 and 586 are SAE Brass Automotive Posts, and all we offer as far as posts go. The Ibar doesn't really work with the 1200. The posts are reversed from the battery the Ibar was intended for, so you would have to reverse the Ibar to make it work. This will not effect the use of the battery or kit, but you will have the negative Ibar terminal on the positive battery terminal and the positive Ibar terminal on the negative battery terminal.
Old 10-20-2010, 04:18 PM
AllenH427's Avatar
0/11 ssssss841
http://www.autozone.com/autozone/par...32327_27122_0_
That is my current battery and the Knu terminals fit perfectly on it...
Will the Ibar 551 fit my needs? I want a post for my Knu terminals and then one additional screw so I can put ring terminals over..
Old 10-21-2010, 02:28 PM
0/11 sssss1016
The 555 gives you the options to run side terminals and then either two sets of top posts or one set of top posts and one set of ring terminals.
Old 10-21-2010, 06:58 PM
AllenH427's Avatar
0/11 ssssss841
Yeah but I'm asking about the 551...
Old 10-21-2010, 10:19 PM
scottiej's Avatar
0/11 ssssss279
The 551 will work perfectly with the I-BAR terminal adaptor we have available. Will give you the option of side and top connection.
Scottie Johnson
XS POWER
Old 10-21-2010, 11:13 PM
AllenH427's Avatar
0/11 ssssss841
Link to said terminal adapter? I can't find it on your site.
Old 10-22-2010, 12:09 PM
0/11 sssss1016
Toward the bottom of the accessories page 551 and 558 Accessories XS Power
fs d1200 newarkbeast973 Wiring, Electrical & Other Installation Equipment 11 10-03-2010 02:37 PM
xs d1200 or optima yellowtop? slamnride Wanting to Buy (WTB) 0 02-18-2010 07:41 PM
XS Power D1200 Rogers Wanting to Buy (WTB) 2 02-01-2010 08:41 AM
xs power d1200 xxxbasshead General Car Audio Discussion & Questions 0 11-10-2009 11:56 AM
