d3400 w/ ibar - Car Audio Classifieds!
Old 10-19-2010, 08:45 AM
newarkbeast973's Avatar
0/11 sssss7810
Default d3400 w/ ibar
I have a d3400 with the ibar and the tall and short sae post! now I have the sae post where they belong. now to use the other 2 openings on the ibar, what type (size) bolt can be used? the opening for a bolt that is on the side is huge and the one up top is small. was it suppose to come with something to fit it? or do I have to figure out what size it is and go get a few bolts? just wondering how to add all the wires I have up front
New build coming soon!!
Old 10-20-2010, 09:46 AM
0/11 sssss1016
Ok let me try to figure this out. Do you have the 551 (pair of side posts and a pair of top posts) or do you have the 555 (pair of side posts and 2 pair of top posts). From what it sounds like you have the 555, which should have came with two sets of posts and bolts for the posts to use on the IBar kit.
Are you talking about the side terminal size? If so that is like the standard GM side terminal, which is a 3/8". The top terminal sizes will be the same as the battery which is an M6 thread.
If I missed anything or you need any more info just let me know.
'1.888.497.7693 x1211
d3400 newarkbeast973 General Car Audio Discussion & Questions 6 09-17-2010 09:55 AM
i bar 555 with d3400 MiX General Car Audio Discussion & Questions 15 05-07-2010 10:09 AM
Wire, fuse and fuse holder, ibar corey0928 Wanting to Buy (WTB) 6 04-27-2010 12:10 PM
What are the specs on the D3400? cokemoe General Car Audio Discussion & Questions 3 10-08-2009 06:07 PM
d3400 vs. d5100 Antstar24 General Car Audio Discussion & Questions 6 08-22-2009 01:45 PM
