aero port question - Car Audio Classifieds!
Old 10-19-2010, 10:27 AM
cadillac214's Avatar
0/11 ssssss344
Default aero port question
so i have a stock 8" sub under my rear windshield, and i have my 2 15s in the trunk, so i was thinking that i should take out the 8" sub and put an 8" aero port, does anybody think this a good idea or have a better suggestion?
Old 10-19-2010, 10:30 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You mean porting through the rear deck?
Old 10-19-2010, 10:31 AM
lileddie1127's Avatar
0/11 sssss1225
I took my 6x9's out, box/port rear facing and it made a difference. Rattling went down considerably and output increased a bit more. I'd take the 8" out and see how it sounds first.
6th order coming soon!
Team Juggernauts
Old 10-19-2010, 10:49 AM
burzendowski's Avatar
0/11 sssss1736
Does your seat fold down? if so fire the 15's forward and seal them off from the trunk and cover your speaker shelf with a deadner. basically make a mini wall, you will have no trunk rattle and some serious bass.
If not you should just remove the 8" , even remove your 6x9s if you do not need them. If you stick a port in there i would think it would be making a bandpass doing so ,but i would just take out the speakers tho for flow into the car.
Old 10-19-2010, 01:03 PM
0/11 ssssss344
the only thing that folds down is my arm rest and theres a little door behind there, but yea i will try just removing the sub because thats all that there is on my rear deck and cover it with deadener and see how it sounds, thanks for the input guys
Old 10-19-2010, 01:12 PM
poundstone's Avatar
0/11 sssss1635
are you talking about building a box and porting it through there or just gonna put a port in it and use the box you have now? cuz that basically would be a 4th order but prolly isnt gonna sound good you could def do subs forward and use that as your port for the box and seal off the trunk but that also isnt alot of port for 2 15"'s more info is good!!
2011 and 2012 usaci streetbeat 2 world champ
2012 2nd iasca advnw1 and lightweight bassboxing
2013 usaci mod 1001-2k world champ
2013 second meca mod 5
2014 mwspl adv 2 world champ
2014 meca mod 4 world champ
usaci streetbeat 2 world record holder b and k
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
Old 10-19-2010, 01:13 PM
poundstone's Avatar
0/11 sssss1635
well that answers that but you could do subs up and leave that open and vent it through the armrest also depending how big it is it might work better if its bigger then the 8" hole!!
Old 10-19-2010, 01:21 PM
0/11 ssssss344
Default aero port
i already have a box so i was just gonna put a port in the place of the stock sub....
Old 10-19-2010, 01:24 PM
poundstone's Avatar
0/11 sssss1635
well depending of if you have a ported or sealed box its either a 4th or 6th order bandpass but i have a feeling its not gonna work how you want it too because of the amount of cu ft you have in your trunk. if you dont wanna build a new box your best bet is to just remove the sub and use it to get the music in the cab rather then put a port in it!
Old 10-19-2010, 01:26 PM
0/11 sssss1182
you must have a lincoln or something of the sort.
Powered By MAXXSONICS
Aero port maverickdog8 Enclosure Discussion & Design Construction Help 3 09-04-2010 06:38 PM
Help With Aero Port! SUBW123 General Car Audio Discussion & Questions 2 03-04-2010 07:18 AM
quick aero port question blazron22z Enclosure Discussion & Design Construction Help 9 01-25-2010 12:01 PM
6'' PSP Aero Port Thewes Wiring, Electrical & Other Installation Equipment 1 12-15-2009 02:29 PM
