02 s-10 help - Car Audio Classifieds!
Old 10-19-2010, 12:34 PM
bassbear007's Avatar
0/11 ssssss745
Default 02 s-10 help
I am going to redo my 02s-10 ext cab . It has a3510 running off an alphasonik pma1000 at 1ohm sub &ports forward. Will be replacing it with either a 9515 or xl15 an between 3500 &4000 wrms. My questions are what is best for low bass daily an will be competing in 2011 hope to be finished by SBNs, sub&port forward, sub froward port up ,sub up port side ect any help will be appericated.
Old 10-19-2010, 12:46 PM
Hertz5400LincolnLS's Avatar
0/11 sssss3029
Sub forward, port up is what worked best for me in my S-10. Depending on who you ask, you'll get a different answer every time.
SOLD TO: orangelss, SPY, 98GMC, MLyons-Jr (2x), laserred97gt, kmanian1, sotelomichael, dB-r_Electronics, EpicenterDesigns
BOUGHT FROM: SPY, fasfocus00, bones22, dbdragguy, kmanian1, TeamPSI (2x), 80inches, pioneer~saturn, sotelomichael, vic713, dB-r_Electronics, Lance_aka_64
Originally Posted by 80INCHES
just build the box and sit back and let the bass flex the $hit out of ur ride
Old 10-19-2010, 12:51 PM
Dbmonster's Avatar
0/11 sssss1217
Sub forward/port up should produce the best numbers
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 10-19-2010, 12:56 PM
basebalz13's Avatar
Loyal Member
0/11 sssss2242
Single sub, sub forward port to the side or sub down port to the side.
Street 4- 160+
Drive-by 4- 135+
i saw david's work , impressed !!!!
And so were the judges!!!
Sorry man, that was so insensitive of me!! I've been there before!!
Old 10-19-2010, 01:04 PM
0/11 ssssss745
Thanks fellows thought about downfiring but want to keep everything below window line and amps will be in the floor don't know if sub beating down at them will be good. also for best #s and desent sound would you use areoport or slot.
Old 10-19-2010, 01:07 PM
basebalz13's Avatar
Loyal Member
0/11 sssss2242
Subfoward and port to the side. Single 6" Aero should be nice.
Street 4- 160+
Drive-by 4- 135+
Old 10-19-2010, 01:10 PM
0/11 sssss3029
Originally Posted by Hertz5400LincolnLS View Post
...Depending on who you ask, you'll get a different answer every time.
Told ya you'd get a lot of different answers.
Old 10-19-2010, 01:15 PM
0/11 sssss3029
Oh and this should be your answer right here...subs forward, port up
TaylorFade's run at World Finals. - Car Audio Classifieds
Old 10-19-2010, 07:08 PM
0/11 ssssss745
Thanks hertz thats it sub forward port up 9515f psi built sub. Now got to start tearing out old and building new.
