Quick WiniSD Question - Car Audio Classifieds!
Old 10-20-2010, 07:35 AM
tntahoe's Avatar
0/11 sssss1196
Default Quick WiniSD Question
Ok Ive used winisd before to build a ported box and it sounded great but I recently ran across a new program and it gave different numbers than winisd. So my question is when using winisd to calculate your port length. The port length it gives you is this the physical port length or what? Lets say my port is 14" height by 2" wide and winisd says the length should be 12" long for a given frequency, is the 12" my wood length or is the correction factor added into making my actual wood length 11"
Old 10-20-2010, 07:42 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
depends if you are pulling your balls back or not
Old 10-20-2010, 07:43 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
Either way very respectable numbers
Old 10-20-2010, 07:45 AM
tntahoe's Avatar
0/11 sssss1196
are you ****ing serious dude
0/11 sssss1904
Feedback Score: 22 reviews
12" is the actual port length
Old 10-20-2010, 07:46 AM
0/11 sssss1904
^^ u cannot ask a simple question without some smartass making comments
Old 10-20-2010, 07:47 AM
tntahoe's Avatar
0/11 sssss1196
thank you sir
Old 10-20-2010, 07:49 AM
0/11 sssss1904
if your doing a "slot port"..some call it a "breather hole"..or L shaped port.. the measurements given it the actual port length..if your a inch or so off...ull be tuned about 1 to 2 hertz lower..higher
kmanian1's Avatar
mine>yours
0/11 sssss2130
Did someone wake up on the wrong side of the bed?
Old 10-20-2010, 07:50 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
better than a dumbass making comments
Quick Box question cthedinger Enclosure Discussion & Design Construction Help 7 06-11-2010 10:51 AM
quick question crownvicon26's General Car Audio Discussion & Questions 9 11-20-2009 12:12 PM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
Quick Question 350zkid General Car Audio Discussion & Questions 10 04-15-2009 03:28 PM
Quick question. rdaudioman1256 General Car Audio Discussion & Questions 3 11-16-2008 12:09 PM
