Problem with my Stetsom amp...sort of... - Car Audio Classifieds!
Old 10-21-2010, 03:15 PM
528hz's Avatar
0/11 sssss1792
Default Problem with my Stetsom amp...sort of...
So I was doing some testing the other day on the TL, running my Stetsom 4k2d, and after about an hour beating on everything, I started to get this weird, distortion coming from the subs. Here is what happens:
At low volumes (4-5 clicks on the HU), my subs start moving in-and-out of phase and sounding like they're blown; similar to what engines noise sounds like if you have a ground issue... The subs aren't blown though, I checked them.
This ONLY happens at low volumes, and once you turn it up, everything plays normal.
I've talked to a few people about this and pretty much concluded that it's something having to do with the RCAs from some end. Most likely on the amp.
One guy I talked to has this problem with his SD 8k, and it does the exact same thing.
I'm going to pull everything out this weekend and see, but just wanted to get some feedback from you all and any who have had this problem before.
Old 10-21-2010, 04:59 PM
willie3719's Avatar
0/11 ssssss475
Ground issue somewhere
pioneer avh p4200dvd[i]
4 sets of ascendant carbon mids
2 set rockford power t2 tweeters
Rockford power 4inch coax
DC 3.5k (2soon) DC 175.4(also 2 soon)
DC XL15s x2
Trippi, on 18 March 2011 -09:42 PM, said:
But at the end of the day that is my truck and if I want to take a sledge hammer to it I can. So f ck you. Thanks everybody for all of your concerns and I will keep you all posted.
Old 10-21-2010, 05:03 PM
tacomaguy1's Avatar
0/11 sssss4401
just turn it up to where it doesn't do it
Old 10-21-2010, 05:14 PM
528hz's Avatar
0/11 sssss1792
I honestly don't think it's a ground issue, but I'll check everything out.
LOL...no, I want to fix what the problem is...
Old 10-21-2010, 05:44 PM
Beerdrnkr's Avatar
0/11 sssss1231
Sounds like an RCA issue. I had that same problem a long time ago. Check to see if your RCA's are pinched somewhere.
Old 10-22-2010, 12:40 AM
0/11 ssssss917
try a new rca splitter going into your stetsom amp?
Old 10-22-2010, 05:20 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Its probably happening at high volume as well. Just the issue is overpowered by the incoming signal. Have you tried another amp yet and see if it does the same thing?
Old 10-22-2010, 07:19 AM
willie3719's Avatar
0/11 ssssss475
Or this^^^^^^ take a piece of speaker wire strip the two ends. Wrap it around one of the RCA terminal on he back of the radio then touch the other side to the radio chassis see if hat helps. If not I'd bet its a bad ground somewhere
DC XL15s x2
Old 10-22-2010, 10:29 AM
528hz's Avatar
0/11 sssss1792
LOL! Thank God it was as simple as it was. The problem was indeed the RCAs. I had one that fell out of the input on the amp. It was barely hanging on...
Thanks for all the suggestions, fellas! I always feel it best to ask for any ideas before I start looking around to minimize the search.
Old 10-22-2010, 12:01 PM
upzaudio's Avatar
1upz all on the meter
0/11 ssssss322
[QUOTE=528hz;873081]I honestly don't think it's a ground issue, but I'll check everything out.
Honestly it sounds like a ground issue there is a way to ground ur rca's that usually with fix this unfortunately I couldn't help u on how. Edit:
nvm see u fixed it
I'm sort of new here. Sevening New Member Orientation 9 09-16-2010 12:20 PM
What sort of sub would you make this into? hornedfrog1985 General Car Audio Discussion & Questions 22 04-09-2010 11:26 PM
What sort of canine should I get? Sonically_Sound Off Topic Chat 63 11-29-2009 07:02 PM
Did i get a great deal or....noob help sort of haha mikeyg402 General Car Audio Discussion & Questions 7 09-14-2009 03:22 PM
