What the frick! - Car Audio Classifieds!
Old 10-22-2010, 02:08 AM
0/11 sssss4511
Feedback Score: 52 reviews
Default What the frick!
Noticed the top plate on my tc9 motor is starting to lift from top slug. What the hell why would this happen and THE FRICK?
Pretty upset. Pulled the motor out of the box I had it packaged in to keep it same and was looking what needed to be cleaned and I noticed it.
Now it has not shifted in either direction not even by a tenth. Question is should I have it rebuilt or build a driver as it is? I've never had this happen before or even really seen it.
Put the orange wrapper underneath so you can see how it looks like. Only one side is doing this also freaking wierd
Visible here also.
its not always about cone area people, dont forget to determine the displacement of comparing multiple sub setups.
sd x xmax=total displacement
Old 10-22-2010, 02:10 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
what the frick?
92 Ranger Walkthrough
(Under Construction)
Old 10-22-2010, 02:12 AM
0/11 sssss4511
Originally Posted by RidnClean View Post
what the frick?
Censorship
good ole tc sounds QC
I would have it fixed but I have ocd on my stuff. I'm even contemplating pulling my motors apart because slugs are different sizes
Old 10-22-2010, 02:13 AM
0/11 sssss4511
Yeah I already messaged and emailed for it be done. Still freaking upset wish I would have seen it sooner.
Old 10-22-2010, 02:15 AM
well think about how fragile ceramic is, do you want motor to come off and possibly land on the mag band?
Old 10-22-2010, 02:20 AM
0/11 sssss4511
Hells no only issue is getting it apart without chipping or damaging the top ferrite slug. Other side is glued down perfectly fine. Loctite and press? lol
Old 10-22-2010, 02:21 AM
orangelss's Avatar
I Role Old School
0/11 sssss2112
go buy a water pic and some JB weld epoxy. Use the water pic to "squirt" the jb weld under the top plate. Add as much weight as you can stack safely onto the motor and wait for the epoxy to set and cure. Will be good as new.
My Allis has a big ass!!
Old 10-22-2010, 02:28 AM
0/11 sssss4511
I was actually going to message you figured I should see what everyone has to offer as far as ideas.
Only issue I see is adding the weight to actually get the top plate to sit flush again. I was basically on top of the motor right now on one side and the top plate did not budge at all.
Will most likely be sending this beasty out tomorrow as I was planning on rebuild next week.
Old 10-23-2010, 01:09 AM
SoCalBean420's Avatar
время решает все
0/11 sssss7110
Feedback Score: 42 reviews
Oh wow, talk about bad luck
