ford alternator - Car Audio Classifieds!
Old 10-22-2010, 12:11 PM
silentbass's Avatar
0/11 ssssss345
Default ford alternator
so my truck is having issues with the lights dimming..even wit no draw...i saw a previous post where a customer of yours used an external regulator to solve this..was curious if i bought a mechman alternator for my 98 ford explorer sport not sohc 4.0...if it came wit an external regulator or if its an additional cost..if so how much?
TEAM HZ ADDICTION
98 Ford Explorer 2dr
caco refs: puredynamics
ca.com refs: 1ndatrunk, ent3rdadragon,psychoacoustics, Tez, Shizzzon, TeamSouthrnBass,Dadon,joe14,90accordman, thegreatestpenn, dcmcki
Old 10-22-2010, 04:15 PM
MECHMAN's Avatar
0/11 sssss1142
We can add the external regulator option to any MechMan alternator for $99 additional.
However, If everything is correct with your alt, bat and wiring, you should not an external regulator to prevent dimming.
regards
Matthew
Old 10-23-2010, 12:17 PM
silentbass's Avatar
0/11 ssssss345
lights dim regardless if car is running or not or even wit no system period..i think regulator is going bad in my current alt..and my other ho alt acts the same....i think the higher viltage frm the mla might have caused sum harm to the regulators
TEAM HZ ADDICTION
Old 10-25-2010, 09:13 AM
MECHMAN's Avatar
0/11 sssss1142
If the lights dim regardless if the vehicle is running or not, it is obviously not an alternator problem.
More than likely, the higher charging voltages of the MLA have overheated the battery, and significantly reduced the capacity of your battery, making the lights dim under very light loads. I would address the battery first.
FS:Ford 200amp 3G 1 Wire Alternator twistedchild420 Wiring, Electrical & Other Installation Equipment 11 09-13-2010 03:01 PM
300 amp Ford 3G series alternator The Doctor Wiring, Electrical & Other Installation Equipment 12 07-15-2010 08:19 PM
Ford 130 Amp alternator Josh Wahlie Wiring, Electrical & Other Installation Equipment 1 06-10-2010 01:43 PM
WTB 250-350+ Amp Alternator for a 2000 5.4L Ford F-250 Josh Wahlie Wanting to Buy (WTB) 4 02-02-2010 09:55 AM
