enclosure specs. someone? - Car Audio Classifieds!
Old 10-22-2010, 05:19 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
Feedback Score: 41 reviews
Default enclosure specs. someone?
can someone tell me the ACTUAL specs on this enclosure.
enclosure
29.5" deep
35" high
44" wide
1.5" thick on entire.
port
17.5" long
8" wide
31" high
bracing
3x3 post in center. 32" long
will have 2 18" subs in it. i need the specs after all displacements.
Old 10-22-2010, 05:24 PM
Prohibited Sellers/Buyers
0/11 ssssss607
is it just 1 layer of 3/4 mdf? any bracing?
Violence*'s Avatar
OCD Member
0/11 sssss7568
oops forgot that part. whole enclosure is 1.5" thick. one brace 3"x3" in the center.
Old 10-22-2010, 05:27 PM
MisterGrubbs's Avatar
0/11 sssss2358
Edit
Double all the way around, after port and the single brace(no 45's and no woofer displacements)
I come up with around 17.25 at 34.5hz
Just rough guesstimate
Old 10-22-2010, 05:28 PM
0/11 ssssss607
looking like 17.2 or so after all displacements tuned to approx 33.5 hz
Old 10-22-2010, 05:29 PM
0/11 ssssss607
my numbers are so close you wont even know the difference if it is slightly higher or lower
Violence*'s Avatar
OCD Member
0/11 sssss7568
yes 1.5" thick the entire enclosure. including baffle. i added 5 more layers to the baffle but there not int he picture. there just filling in around the accordion boot.
i got 20ft3 with no port. 15.12ft3 with port and no sub displacement.
Old 10-22-2010, 05:34 PM
0/11 ssssss607
and your sitting around 12.5 sq in of port per cu ft
and for sub displacement i figured .24 ft^3 per sub, as most 18s will fall close to that
Old 10-22-2010, 06:36 PM
Violence*'s Avatar
OCD Member
0/11 sssss7568
hmmm. i wonder if thats enough port.
Old 10-22-2010, 06:50 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
17.13ft^3 @36.21hz after all disp.
SHABAM
Z v.2 18 enclosure specs? 1ndatrunk (Sundown Audio) 3 07-07-2010 01:41 PM
Cdt com 626 specs T-Money1111 General Car Audio Discussion & Questions 5 03-14-2010 10:43 PM
What is net mean in enclosure or get me good specs hifonicsviii General Car Audio Discussion & Questions 4 01-30-2010 12:31 AM
specs korey_hofer General Car Audio Discussion & Questions 12 12-28-2009 05:46 AM
