05 Tahoe: Using stock XM antenna for pioneer HU? - Car Audio Classifieds!
Old 10-23-2010, 03:03 AM
thisistiny's Avatar
0/11 ssssss663
Default 05 Tahoe: Using stock XM antenna for pioneer HU?
Looking to get http://www.sonicelectronix.com/item_...EX-P920XM.html, an XM module add on for my Avic-D3.
Now, I would like to use the stock XM antenna that is already on the Tahoe. Is this possible? One of the wires (behind the HU) has to be the wire, RIGHT?? Cause my stock HU had XM on it.
If anybody has done something like this, could you help me out pleaseee!
On a side note: If anybody is selling Pioneer GEX-P920XM, hit me up!
'05 Tahoe
HU: Pioneer AVH-P4200DVD w/ XM add-on
Fronts: Crescendo CCX65
Rears: Alpine SPS-600
Powered by: Sundown SAX-100.4D
Subs: JL Audio 2 10w7 - 3ft^3 @ 35hz
Powered by: Sundown SAZ-1500D
Old 10-23-2010, 09:56 PM
FAUEE's Avatar
0/11 sssss1081
Typically they use the older style 2 plug FAKRA connector. And in most cases the XM brain is not in the radio, its usually located somewhere close, but not always. In my gf's car its in the driver rear quarter panel. So if your antenna connection is located all the way out there you may be boned.
Old 10-23-2010, 10:12 PM
Dbmonster's Avatar
0/11 sssss1217
yup, you sure can
I used to do this all the time. the factory xm antenna uses the same wire connection as an aftermarket unit. the factory tuner is not in the radio though, it is behind the glove box, it's a small metal box with a wire harness plugged into one side and the antenna on the other. i usually remove the tuner box and mount the new tuner in the same spot.
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
FS: Honda Antenna Adapter fasfocus00 Wiring, Electrical & Other Installation Equipment 8 07-04-2010 05:33 PM
Gps antenna. quaddropper General Car Audio Discussion & Questions 6 05-30-2010 07:48 AM
Make an antenna F3M4 General Car Audio Discussion & Questions 11 08-24-2009 08:34 PM
WTB CB antenna MaTT6387 Wanting to Buy (WTB) 9 07-12-2009 03:04 AM
Antenna wire help. i need this quick. waresgaragestereo General Car Audio Discussion & Questions 7 04-21-2009 09:53 PM
