headunit at 2 ohm stereo? - Car Audio Classifieds!
Old 10-23-2010, 03:32 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default headunit at 2 ohm stereo?
I saw where a couple companies sale 2 ohm mids and they say you get the most out of your headunit power with these. Are most headunits internal amps 2 ohm stereo stable? I have kenwood excelon 794
2 FI bl 18's walled in 2012 scion xb
Old 10-23-2010, 03:33 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
not as far as i know...
-Youtube Channel
Old 10-23-2010, 03:34 PM
0/11 sssss3344
yeah i wouldnt try that
sundown nutthugger
so dont hate!
refs ssackett spy resko cruzin22z 1loudyukonxl bumpinbuick theemichealhughes ss audio 2loud4youmorris atsaubry crxbumpin pshcyoacoustics big c yukon crescendoaudio skatinbassplaya keifersracing getlow galaticmonkey getlikeme bass14 twisted turdfurgueson2 enemyofsilence taylorpro duran anton miller kowboy willie3719 kickerassman
TEAM SUNDOWN
TEAM EVO
TEAM INCRIMINATOR
TEAM BETTER LUCK NEXT YEAR
TEAM WHATS A WALL
Old 10-23-2010, 03:36 PM
98Expo's Avatar
0/11 sssss1929
infinity has a set that says 2 ohm per speaker and will work on any factory radio, I asked local shop here and they say they sale alot of those and do run them on headunits. I will see if I can find the speakers and where i read it, it was on crutchfield site
Old 10-23-2010, 03:37 PM
koopa's Avatar
0/11 sssss2800
examples of companies .
nvm
edit just saw ur new post
2008 tahoe
CDA9887 active
6 vifa tweets
2 10" Dayton mids
subs
tweets amp clarion 400.4
Mid amp autotek 400.4
Sub amp soundigital 12k
4 alts 1 stock 3 dc power alts
3 runs of shok wire
11 batts 1 deka and 10 shuriken
0/11 sssss3344
well go for it tell us the results idk i dont ever use head unit power
sundown nutthugger
so dont hate!
TEAM SUNDOWN
TEAM EVO
TEAM INCRIMINATOR
TEAM WHATS A WALL
Old 10-23-2010, 03:46 PM
98Expo's Avatar
0/11 sssss1929
i may try it and if it messes up, i will send back to crutchfield since they said it would work.
i copied this off where i did a search for it:
2 ohms speakers can work with some head units, mostly because the Kappa speakers are really 3 ohm, and not for very long. note that impedance varies with frequency. Infinity also attests that the stock wiring adds an ohm or so, so in the end, the load on the headunit is closer to 4 ohms. they argue that 4 ohm speakers are closer to 6 ohms at the head unit so a Kappa speaker is able to get rated power out of the headunits tiny amp.
you're dealing with like 15W RMS per channel of listenable volume anyway, it's not a lot of power. no one turns their head unit up to full volume while powering speakers because the distortion levels are so high with head unit amplifiers
Old 10-23-2010, 03:47 PM
98Expo's Avatar
0/11 sssss1929
i never use it either, but I sold everything and just hookin this up so I have something to listen to until new car next month
Old 10-23-2010, 03:51 PM
koopa's Avatar
0/11 sssss2800
u might as go with the cheapest speakers you can find if it is only for a month .
2008 tahoe
CDA9887 active
6 vifa tweets
2 10" Dayton mids
subs
3 runs of shok wire
Old 10-23-2010, 03:52 PM
0/11 sssss2264
Feedback Score: 33 reviews
yes they work ive used them both on stock and aftermarket stereos, no heating warming issues. none of that
pretty sure the lms coil just aids in some woogey boogy shitt called SQ
Whats prototype about an off the shelf design in an off the shelf casing?
stereo jrplayer36 Wanting to Buy (WTB) 5 03-27-2010 01:22 PM
Bose SA-3 Stereo amp x 3 Bryan Miscellaneous Stuff For Sale 0 01-15-2010 08:53 AM
FML v. stereo grimreper912003 Uncensored Off Topic 16 12-09-2009 07:27 PM
Online car stereo quaddropper General Car Audio Discussion & Questions 2 04-20-2009 10:24 PM
