WTF is this noise?? - Car Audio Classifieds!
Old 10-23-2010, 07:44 PM
0/11 ssssss651
Default WTF is this noise??
So, I was listening to my friends setup today,& Heard a loud pop, Sounded like the woofer bottoming out, But was not, I Turned the rear 6x9s off, Turned it to the same song, same volume, No popping noise? Has anyone had this problem?
Sundown SA-12s
Sundown SAZ_1500
Sundown x2 SAX-100.4D
But not team sundown
refs:corona_jeff, andrewtexas123, fasfocus00, Nickatina, 97maxima, Dirtydood, Markak134, Curse,Cl1ckClack,cdawgstalon,JarvisB,Boomsday,Indy bangin,surreal,korn4life
Old 10-23-2010, 07:48 PM
6x9's bottoming out
Old 10-23-2010, 07:49 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Is the pressure from the sub causing the 6x9s to bottom out? When you turned the off the 6x9 it wasn't playing so it may not occur in this situation but when it is playing the woofer is already moving so the additional pressure from the subs could cause over excursion?
Old 10-23-2010, 08:01 PM
0/11 ssssss651
Originally Posted by xander_crews View Post
6x9's bottoming out
^My thought exactly..
Okay, So the subs will cause this? I also turned the 6x9s on, but disconnected the subs, & they didn't so I am assuming it is the woofers making it happen??
Sundown SA-12s
Sundown SAZ_1500
Old 10-23-2010, 08:06 PM
Partially Unwound
0/11 sssss2697
If the 6x9's are causing the noise speaker baffles or enclosures build around the back 0f the 6x9's should help
Old 10-23-2010, 08:08 PM
0/11 ssssss651
I think we will be taking them out, Sealing them off & fiberglassing some 6.5s into the rear pods
Sundown SA-12s
Sundown SAZ_1500
Old 10-23-2010, 08:42 PM
0/11 ssssss651
So the subs cause it??
Sundown SA-12s
Sundown SAZ_1500
Old 10-23-2010, 09:05 PM
newarkbeast973's Avatar
0/11 sssss7810
it had to be the subs if he said he disconnected the subs and the 6x9's were good. then it is the pressure of the sub!
New build coming soon!!
Old 10-23-2010, 09:12 PM
0/11 ssssss651
I'm not so sure on that, After having the 6x9s OFF we turned the Same song back on, same volume, & Nothing happened
Sundown SA-12s
Sundown SAZ_1500
Old 10-23-2010, 09:20 PM
the 6x9's can't take the pressure coming form the sub /thread
noise on 4ch? tymoto21 General Car Audio Discussion & Questions 4 09-13-2010 03:22 PM
amp fan noise dylan9999 General Car Audio Discussion & Questions 1 06-23-2010 11:44 AM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
fan noise gbo559 General Car Audio Discussion & Questions 1 12-28-2009 01:52 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
