Transmission line enclosures - Car Audio Classifieds!
Old 10-25-2010, 12:05 PM
sqoverspl's Avatar
0/11 ssssss184
Default Transmission line enclosures
Does anybody on here run a tline? I have been debating on building one for a while and Im thinking of trying it out after a bit more research. I really want to know the difference in spl between tline and ported and if ported moves more air or not. Right now I have a ported box tuned at 25-26hz and Im thinking a tline tuned at 30ish(need to really research this first) would maybe have better low end. The overall goal is of course loud, really clean and really low bass. If this all goes well Ill lose a seat and gain a LOT of cargo room back.
Also what are everybody's opinions on sub and port locations? So far Im thinking sub and port next to each other side firing in the very back.
Mazda Tribute (built for sq)
Clarion dxz785, faital 6's, selenium horns, and one psi re hc
Old 10-25-2010, 12:16 PM
Dbmonster's Avatar
0/11 sssss1217
I've been wanting to build a t-line for a long time now, I did a bit of research on them a while back, and from what I understand you don't tune them to a desired frequency, you tune them to the fs of the woofer you are using. So the driver you use has a HUGE impact on the overall sound and how low it will play. t-lines are very efficient and pretty much unbeatable when it comes to sq from what I hear. But I also have read they are not great for Spl, but I assume based on your user name that's not what your after.
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 10-25-2010, 12:37 PM
0/11 ssssss400
Built a tapered tline for sq.
<<<20 Hertz SEALED on the DASH.
Ohio Generators High Out Put Alternators
Old 10-25-2010, 12:44 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
i'm running several T-lines atm. (granted they are all for HT use) are they made for spl, no. IMO, they are very efficiant and have great range if you build it right and with the right drivers. the downside is they are very large. to give you an idea, mine for a single 18" is 8' wide, 24" deep, and 19" tall. spy made one for a car that was for a pair of 8's that took up 3ft^3 or so IIRC.
Proud Member of CAAA!
Old 10-25-2010, 12:49 PM
sqoverspl's Avatar
0/11 ssssss184
Im really looking for cleaner, and stronger low end with the same output as my ported box now. I dont want to go for a tapered line because Im pushing it as it is with t/s specs. The sub has psi soft parts so I cant just look up the t/s parameters on it so I figured it would be easier to just build a basic single fold tline.
and I cant believe I thought I had a choice to build one or not, of course I have to
Old 10-25-2010, 12:52 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
IIrc the area of the line should match as closley as possible the surface area of the woofers cone and the line needs to end in a fraction of a a wavelength that is determined by the woofers Fs.
As far as the tapered part I never got that far.
My description is prob clear as mud - lol.
sqoverspl's Avatar
0/11 ssssss184
size is not a problem Ive come to terms with the loss of one of my seats, because when you think about it, its not my ass that has to squeeze back there with a few other people now is it
Old 10-25-2010, 12:56 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
lawl. my 18 gets impressivly loud on very little power. i can have window flex in my living room with only 400 rms going to it. i have 850 rms i can tap into, but thats going overboard.
Old 10-25-2010, 01:00 PM
sqoverspl's Avatar
0/11 ssssss184
How is the mechanical power handling on them? Id like to run all "1500 rms" to mine.
Old 10-25-2010, 01:15 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Efficiency and extension are the thing with TL's. From what I have read, they are +1.5db over standard ported. Traditionally the line area = Sd (effective cone area) of the sub and are usually tuned to the sub's Fs. They do get huge though, but if you have the room, go for it. I have been dying to try one, but I just don't have the room in my trunk for much sub.
For anyone who thinks TL's don't ALSO get loud, I saw a TL for a pair of 15's in a SQ vehicle doing 57's on two Linear Power amps. I think the subs were only seeing like 1kw apiece too. The box was 25cf though. Lol.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Why Would This Happen (Engine/Transmission?) BassikInstincts General Car Audio Discussion & Questions 6 03-21-2010 01:13 PM
Decided to change the transmission filter and fluid themgators511 General Automotive Chat 24 02-04-2010 11:23 PM
Transmission Line Enclosure for Boomintahoe DNick454 Enclosure Discussion & Design Construction Help 11 08-13-2009 01:12 AM
Three Enclosures russhay78 Miscellaneous Stuff For Sale 7 05-29-2009 11:26 AM
T-line enclosures, opinions? SPY General Car Audio Discussion & Questions 29 11-05-2008 09:41 AM
