trailblazer help - Car Audio Classifieds!
Old 10-25-2010, 02:02 PM
Ego Crusher
0/11 sssss1834
Default trailblazer help
I'm currently at work right now so I cant check the dimensions my self Im needing the cargo dimensions for a trailblazer at there shortest points. This will be for a box for 2 dd 9515's
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 10-25-2010, 02:08 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Shortest points? My box for the Omega's was 46w22h24d. That left room for the batt behind the box. 8^3 net btw
Old 10-25-2010, 02:24 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
If you do what I did with my current box, you get more depth by moving the battery to the side.
Old 10-25-2010, 02:32 PM
Ego Crusher
0/11 sssss1834
I actually need more width the box my friend has is 48x28x19(wxdxh) would that fit?
Old 10-25-2010, 02:34 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
46 squeezes into the wheel wells tightly, pretty hard to wiggle. 48 is too wide. I could sell you my box but you're not local and it's tuned a bit low for DD's lol
Old 10-25-2010, 02:37 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Remember to give the port room to breathe. 28d WITH that room is most likely not going to allow you to click the backseats in. Do you have a battery going back there somewhere?
Old 10-25-2010, 02:39 PM
Ego Crusher
0/11 sssss1834
no
Old 10-25-2010, 02:42 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
No battery back there...what are you powering 2 9515's with? Where do you plan on putting the batteries you will need to power them? Just trying to help a fellow TB owner here, no attitude I pormise
Old 10-25-2010, 02:44 PM
Ego Crusher
0/11 sssss1834
I understand. They will be powered but 2 dd m1a amps for now no batteries yet.
Old 10-25-2010, 02:47 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
How wide is the port?
I assume you wanna keep the backseats FULLY usable?
Why not get another box made another 1-1.5" shorter to be under windowline?
160+ in a Trailblazer. boilermaker-744 General Car Audio Discussion & Questions 41 08-24-2010 12:58 PM
4 10s in my trailblazer nuboot Team Teamless 0 05-29-2010 06:45 PM
03 Trailblazer help Scapelli21 Enclosure Discussion & Design Construction Help 37 02-19-2010 12:58 PM
04 Trailblazer Take 2 Andrew Member Rides & System Pictures 45 02-17-2010 10:55 PM
My '04 TrailBlazer LT Andrew Member Rides & System Pictures 18 09-22-2008 11:31 AM
