3-15s or 2-18s in Tahoe - Car Audio Classifieds!
Old 10-25-2010, 08:37 PM
tntahoe's Avatar
0/11 sssss1196
Default 3-15s or 2-18s in Tahoe
I have an 03 Tahoe and I plan on running the cresendo 1000c4 for my mids n highs and the 3kwp for my subs now with that being said Im trying to decide on either 3-15s or 2-18s. I plan on running this in a daily driver and I will not be cranking it up very often but when I do I want it get loud and sound good at it. My previous setup was 4 kicker cvx 12s off of 2 hifonics bxi 2006d amps in a ported box tuned to 33Hz. Iver never heard or owned 18s so what are the pros n cons versus 15s.
Old 10-25-2010, 08:41 PM
Prohibited Sellers/Buyers
0/11 ssssss752
Id reccomend the 2 18s if you aim for higher end subs. I love the sound of 2 18s for some reason, though youll have increased cone area with the 15s, I just like the thought of 2 18s better
Old 10-25-2010, 08:43 PM
AllenH427's Avatar
0/11 ssssss841
The 18s will have 509 sq in. of cone area
The 15s will have 530 sq in. of cone area
That's a pretty similar number right there^^... 3 15s vs 2 18s of the same sub, the 15s will obviously have more motor force, but you have to consider you'd be running those 3 at lower power with your amp. I'd get 2 18s... A lot of nice subs can handle 2kw rms perfectly.
TEAM XS - MECHMAN - FI - AUDIOQUE
152.6 OUTLAW AND CLIMBING
Old 10-25-2010, 08:48 PM
TNJ
0/11 sssss7882
i have an 02 tahoe and was thinking of going the 2 18's route as well. i think thats gonna be better than the 3 15's. plus it will just look neater with 2 subs.
Old 10-25-2010, 08:54 PM
tntahoe's Avatar
0/11 sssss1196
any brand and model suggestions and why
Old 10-25-2010, 09:03 PM
TNJ
0/11 sssss7882
how much you looking to spend? going on a CA 3k at 1ohm or .5ohm?
Old 10-25-2010, 09:17 PM
tntahoe's Avatar
0/11 sssss1196
it really doesnt matter to me if i run it at 1 ohm or 0.5 ohm, will either cause the amp to fail prematurely or something, im not sure on my price range but i figured i would just wait til i ran across a good deal on some
Old 10-25-2010, 09:32 PM
thisistiny's Avatar
0/11 ssssss663
3 15's!!! No good reason particularly. Either way I'm interested in either set up you go with. As I drive a tahoe also. What's your electrical like? I'm going with 2 sa-15 for my next set up personally.
'05 Tahoe
HU: Pioneer AVH-P4200DVD w/ XM add-on
Fronts: Crescendo CCX65
Rears: Alpine SPS-600
Powered by: Sundown SAX-100.4D
Subs: JL Audio 2 10w7 - 3ft^3 @ 35hz
Powered by: Sundown SAZ-1500D
Old 10-25-2010, 09:33 PM
AllenH427's Avatar
0/11 ssssss841
Crescendo amps are warrantied at .5 ohms, so you don't have to worry about the amp failing. Running at .5 does put more strain on your electrical than 1 ohm. I'd run at .5 if I had one of those amps though.
Old 10-25-2010, 09:37 PM
tntahoe's Avatar
0/11 sssss1196
stock electrical as of right now
2 DP 21 in Tahoe Team Nemesis-Jared Build Logs 65 11-08-2010 09:43 AM
Best HID kit for Tahoe? murderedtahoe General Automotive Chat 43 07-30-2010 09:42 PM
Ideas for box for '03 Tahoe FAUEE Enclosure Discussion & Design Construction Help 0 07-19-2010 12:28 AM
My smashed Tahoe Snwbrdr1 General Automotive Chat 18 06-12-2010 05:18 PM
What would you do if you won Steves Tahoe?? BigC-Expo Off Topic Chat 57 11-21-2009 03:17 AM
